Ipad Mini Fit ?
Posted 11 September 2013 - 04:02 PM
Also what do i have to do to charge it In car ?
Kind regards Panayiotis S
Posted 11 September 2013 - 04:09 PM
There's a couple of methods.
Ideally you need a headunit that has an ipod connection cable so you only have one connection. This would carry audio as well as charging the iPad.
To physically mount the ipad you'll need to combine a mount from eBay/Halfords etc.
eg:
The other way is a combination of power from the 12v connection and a phono 3.5mm audio connection to an auxiliary input on your headunit. It's long winded but cheaper.
Posted 12 September 2013 - 04:56 AM
Posted 12 September 2013 - 07:50 AM
Okay thank you , but how can an auxilliary connection from the ipad to the headunit can charge the ipad ?
It can't. You'll need to charge it independently to the auxiliary connection or use a headunit that has an iPad connection that will charge as well as play music.
Posted 12 September 2013 - 09:32 AM
For example something like this would charge your iPod and play music through its serial connector on the bottom. http://www.caraudiod...a-receiver.html
Whether any one these will work with the iPad mini is another question since they have the changed the connector on the bottom to the lightening one and also its quite new, most head unit at the moment where built for the older iPod connection.
Posted 13 September 2013 - 08:38 AM
Posted 13 September 2013 - 09:50 AM
I doubt anyone has done this other than in show cars. The iPad is the size of the windscreen in a mini...
Posted 13 September 2013 - 11:10 AM
Posted 13 September 2013 - 04:38 PM
iPad mini will be a ok
Posted 16 September 2013 - 12:38 PM
They would be ideal. I think they are roughly double din size nearly.
Posted 21 September 2013 - 06:08 PM
Posted 22 September 2013 - 08:57 PM
Posted 23 September 2013 - 07:41 AM
http://www.minisport...e-binnacle.html
