Knocking Noise From Wheel :(
4 replies to this topic
#1 2009poolesparky
2009poolesparky
  • 103 posts
Posted 12 September 2013 - 08:37 AM
hi everyone, when i go out for a drive i can hear a knocking noise coming from the near side front wheel. it only happens when i go over bumps, but it sounds quite worrying, i had the car up on the ramps and checked everthing, the ball joints look greased and are tight and were new about 18k miles ago, the tie rod end looks good too, the shocks are adjustable spax and they are on a firm setting, it also has hi lo's fitted, the only thing i can see is that the top arm is only about an inch off the bump stop as opposed to the 2 inches on the other side, its got the 10 inch wheels with 7.5 discs any help much appreciated thanks alex
#2 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 12 September 2013 - 09:07 AM
the suspension has dropped on that side, check the knuckle joint and also check that the damper is on the stud properly, mine was banging away with a couple of mm between the nut and damper
#3 2009poolesparky
2009poolesparky
  • 103 posts
Posted 12 September 2013 - 10:36 AM
sorry what is the knuckle joint? or is that another name for the ball joint? everything  seems tight
#4 M J W J
M J W J
  • 976 posts
  • Local Club: not yet
Posted 12 September 2013 - 10:56 AM
Point where the suspension cone (ally bit not the rubber bit) meets the upper arm.
Edited by M J W J, 12 September 2013 - 10:57 AM.
#5 2009poolesparky
2009poolesparky
  • 103 posts
Posted 12 September 2013 - 12:21 PM
oh yes, i know what you mean now, the knuckles are brand new and greased up too looking at the car the drivers side looks like its lower than the passenger side, even though there is more clearnace on the bump stop on the drivers side... confusing, its got hi los but adjusting them are a bit of a pain without taking a wheel off
