Hi all, I'm working on a 12G940 head at the minute, learning to port and polish etc and while I'm working on it the valves are looking a little tired and I think they could do with replacing along with the springs and guides.
The valves are standard big valve dimensions - 91mm by 29 and 36mm, with a single grove collet. I'm also planning to fit 200lb double valve springs and new iron guides.
Does anyone have any recommendations for valves? I can't really justify the expense on rimflos, but minispares have valves at 10 pound a pop - does anyone have experience with these?
Valve guide wise, I've seen plenty of arguments between iron and bronze but I think on the spec of engine I'm building I would rather have the reliability of iron - is this a bad idea?
Are double valve springs worth it? Is 200lb a good weight for an SW5-07 cam with 1.3 rockers? Do I need the lower guide for the inner springs to sit on? What top caps and collets do I use?
Finally, does anyone know where I can get a punch or drift for knocking guides out of the head? All the ones on ebay have too great an inner diameter to fit in mini guides.
Is the sky blue? Sorry too many questions :)
Zik
Edit: And to save me making another thread, has anyone thought of blanking the heater take off and using a sandwich plate to feed the heater and act as a bypass to avoid drilling umpteen holes in the thermostat?
Edited by Zik, 12 September 2013 - 05:40 PM.
