Su Carbs
Best Answer carbon , 15 September 2013 - 07:48 PM
Red jets should be used for either horizontal or up to about 10 degrees downdraft.
Black jets for about 20 to 30 degree downdraft.
Go to the full post
Posted 14 September 2013 - 11:18 AM
cheers james
Posted 14 September 2013 - 12:46 PM
This is just a guess but if you google image hs6 jet they mostly come up black
hs4 jet come up red
so I'd say black are larger for the 1.75" carbs
red are for the 1.5" carbs
Posted 14 September 2013 - 12:49 PM
cheers james
Posted 14 September 2013 - 12:57 PM
wont be size then :)
probably just different plastic
Posted 14 September 2013 - 12:58 PM
I am not sure that the color indicates carb size. A lot of the early small bore Triumphs used jets with the red plastic elbows on them while all the BMC products I have worked on seem to have black elbows.
Regardless, if in doubt, measure the bore of the brass tube. There are indeed different sizes, 0.090" and 0.100" holes.
Posted 14 September 2013 - 01:00 PM
Cheers james
Posted 14 September 2013 - 01:12 PM
No. The bigger hole in the jet has to be used with bigger diameter needles.
It's not so much an upgrade as components that have to work in matched sizes. Remember that SU carbs were used on a tremendous number of make and models of cars, many with much larger engines than the Mini and therefore, greater fuel demands.
Posted 14 September 2013 - 01:14 PM
James
Posted 15 September 2013 - 08:13 AM
Black plastic jets = semi-down-draught
Red plastic jets = horizontal
Available in both 0.090 and 0.100 jet sizes (at least that's what the SU reference manual says, exactly what the difference between the red and black jets is I am not sure, they look very similar).
Posted 15 September 2013 - 08:27 AM
The difference is the hose is slightly longer to allow for the different float chamber angle. If the carbs are horizontal the bottom of the float chamber is closer to the jet, as it angles up and you change the float angle adapter the distance between them increases.
Posted 15 September 2013 - 07:21 PM
Thanks Dan, that makes a lot of sense
Posted 15 September 2013 - 07:29 PM
cheers james
Posted 15 September 2013 - 07:48 PM Best Answer
Posted 15 September 2013 - 07:53 PM
