Servo Brake Pedal
Posted 15 September 2013 - 10:03 PM
Posted 15 September 2013 - 11:20 PM
think its a pin with a split pin in to hold it on
Posted 16 September 2013 - 09:59 AM
just fitted a servo to a none survo peddel box
one end has a pin that you can remove
and the other pin you cant
its spot welded on as you say
I think its the peddel end
that you can remove the pin from
and yes a split pin
Posted 16 September 2013 - 04:31 PM
This is exactly what I found (although the spot welded end is the pedal end) not a disaster as I bought a pedal box as well, just means great fun with shear boltsjust fitted a servo to a none survo peddel box
and yes a split pin
Posted 16 September 2013 - 09:23 PM
It's like a rivet, but it means if you're getting rid of your servo, you have to change the pedal box as well, luckily, I bought a pedal box at the same time so it wasn't much hassle apart from the shear bolts, drilled out and ground off the clamp one, and tapped round with a screwdriver the two going through the dash rail, then replaced them with normal 5/16 bolts, then discovered that a socket's wall is too thick and had to do it 1 flat at a time with a open ended spanner.
A bit of advice to anyone who is planning on fitting a metro master cylinder to a mini, the plate that is held down by the 4 studs which hold the pedal box to the clutch and brake master cylinder and the top engine steady needs 'adjustment', the hole is offset because the way the servo 'linkage' works
