Mg Metro 1275 Clutch And Gaskets Questions
7 replies to this topic
#1 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 16 September 2013 - 06:54 PM
Evening, I am replacing the clutch on my MG Metro 1275 with pre verto clutch, is this ok http://www.minispare...|Back to search
 or is the mg metro clutch different in any way?
Dan
#2 Noah
Noah
  • 4,136 posts
  • Local Club: Essex Mini Club
Posted 16 September 2013 - 07:17 PM
If its pre-verto then thats fine.
#3 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 16 September 2013 - 07:22 PM
Cheers Noah :thumbsup:
#4 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 16 September 2013 - 07:23 PM
Do these gaskets fit the MG Metro 1275 or are they classed as the 1300 ? http://www.minispare.../AJM1140MS.aspx
And these http://www.minispare...c/AJM206MS.aspx
#5 Noah
Noah
  • 4,136 posts
Posted 16 September 2013 - 07:30 PM
AJM206MS - Absolutely fine for all 1275's except cooper 'S'.
For the head gasket set you want AJM1140, it comes with the BK450 head gasket rather than the copper type, bear in mind, they only come with 4 valve stem oil seals. ADU4905.
#6 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 16 September 2013 - 07:33 PM
Another Mini Spares Legend in the making, Super-star Noah :thumbsup:
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 16 September 2013 - 09:20 PM
You only NEED 4 valve stem seals - for the inlets.....  None on the exhausts.
#8 Noah
Noah
  • 4,136 posts
Posted 16 September 2013 - 09:24 PM
Yes you only need, but you'd be surprised at the amount of people that ask why they don't come with 8. There is no issue with having 4, there is no issue with having 8. I suppose it's your choice. Personally I'd be fitting the MPI ones, they're of a much better material. LJQ101160.
