Need Advance Curves
5 replies to this topic
#1 holmesy
holmesy
  • 879 posts
Posted 22 September 2013 - 09:12 AM
this us one for the more technical of us :D
what im after is the advance curves for some dizzy's I know my mg metro dizzy pulls very well in my hot 1310 but I know it can be tweaked to improve. im running mappable ignition so I want to transfer the data over. I'll also make up the maps for other dizzy's for people that need a better base map on their mappable ignition system.
I would like :
mg metro 1275
aldon red and yellow and any of their custom ones would be great if you have the specs of them.
standard 1275
standard 998
and metro turbo
if you have anything else then please don't hesitate. Thank you
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 22 September 2013 - 01:20 PM
Have a look at some I have may help
#3 carbon
carbon
  • 2,590 posts
Posted 22 September 2013 - 07:44 PM
Following data from ARG Metro repair manual supplement AKM4694/8 (1984).
MG Metro 1300 and Vanden Plas with 10.5:1 CR, Lucas 59D4, 41979
20-22 deg @ 4800
14-18 deg @ 2800
10-14 deg @ 1500
4-8 deg @ 1000
0-2 deg @ 600
no advance below 400 (all above are in crankshaft rpm)
Vacuum advance 6-12-9 (starts at 6inHg, ends 12inHg, total 18 degrees crank advance)
Timing at 10 deg btdc @ 1500 rpm, vacuum disconnected
Metro 1300  HLE with 9.75:1 CR, Lucas 59D4, 41938
16-20 deg @ 5500
10-14 deg @ 4000
2-10 deg @ 2000
0-2 deg @ 1000
no advance below 500 (all above are in crankshaft rpm)
Vacuum advance 6-15-9 (starts at 6inHg, ends 17inHg, total 18 degrees crank advance)
Timing at 9 deg btdc @ 1500 rpm, vacuum disconnected
Vanden Plas 1300 with 9.4:1 CR, Lucas 59D4, 41864
24-28 deg @ 5200
23-27 deg @ 4800
16-20 deg @ 2500
8-12 deg @ 1600
0-4 deg @ 700
no advance below 300 (all above are in crankshaft rpm)
Vacuum advance 3-9-8 (starts at 3inHg, ends 9inHg, total 16 degrees crank advance)
Timing at 11 deg btdc @ 1500 rpm, vacuum disconnected
MG Metro Turbo, Lucas 59DM4 electronic, 41932B
15-19 deg @ 4900
13-17 deg @ 3900
11-15 deg @ 2800
9-13 deg @ 2300
2-6 deg @ 1400
no advance below 600 (all above are in crankshaft rpm)
Vacuum advance 1-7-12 (starts at 1inHg, ends 7.5inHg, total 24 degrees crank advance)
Timing at 7 deg btdc @ 1500 rpm, vacuum disconnected
Metro 998, 8.3:1 CR, Lucas 59D4, 41857
20-24 deg @ 4800
14-18 deg @ 2800
10-14 deg @ 1500
0-2 deg @ 600
Vacuum advance 4-11-7 (starts at 4inHg, ends 11inHg, total 14 degrees crank advance)
Timing at 15 deg btdc @ 1500 rpm, vacuum disconnected
Metro 998, 9.6:1 CR (99H907P), Lucas 59D4, 41857
16-20 deg @ 4800
11-15 deg @ 2800
3-7 deg @ 1500
0-2 deg @ 600
Metro 998, 10.3:1 CR (99HA06P), Lucas 59D4, 41857
20-24 deg @ 4800
14-18 deg @ 2800
10-14 deg @ 1500
0-2 deg @ 600
Metro 998 HLE, 10.3:1 CR (99HA06P, 99HA08P), Lucas 59D4, 41907
16-20 deg @ 4800
15-19 deg @ 4000
13-17 deg @ 3300
11-15 deg @ 2800
6-10 deg @ 2000
3-7 deg @ 1500
1-5 deg @ 1200
0-2 deg @ 600
Vacuum advance 3-9-8 (starts at 3inHg, ends 10inHg, total 16 degrees crank advance)
#4 holmesy
holmesy
  • 879 posts
Posted 23 September 2013 - 08:40 AM
thank you both very much. I'll get making some maps :) still looking for a performance dizzy advance curve if anyone has some. I will have a look on aldon's website at lunch
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 23 September 2013 - 06:08 PM
Why on earth are you using dizzy maps?  Doing a full map is nothing like a dizzy map, thats the whole popint of having a mappable system.
Have it mapped you won't look back.
AC
#6 holmesy
holmesy
  • 879 posts
Posted 24 September 2013 - 12:49 AM
im building some base maps to get basic setups running correctly. mine goes on the rr on the 29th
