Diff Casing Torque Settings
Best Answer Guess-Works.com , 23 September 2013 - 07:02 AM
18 ftlb for the 5/16" ( applies to all 5/16" screws, diff side covers,speedo cover and adaptor plate )
25 ftlb for the 3/8"
Go to the full post
14 replies to this topic
#1 Stu1961
Stu1961
  • 633 posts
  • Local Club: Still Looking
Posted 22 September 2013 - 11:09 PM
Hi all,
Just on the verge of finishing off my gearbox build but not sure what the torque settings are for the diff casing to gearbox bolts, 4 x 3/8" UNC and 3 x 5/16" UNC.
Plenty of references for torque settings for studs and nuts in the manuals but mine are bolts with lock tab washers.
Any advice gratefully received
Stuart
Edited by Stu1961, 22 September 2013 - 11:10 PM.
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 23 September 2013 - 07:02 AM   Best Answer
#3 Stu1961
Stu1961
  • 633 posts
Posted 23 September 2013 - 08:31 AM
Cheers John
Stuart
#4 Myminiproject
Myminiproject
  • Just Joined
  • 22 posts
Posted 30 November 2023 - 04:51 PM
Thanks for the torques John.
Look what happened to the left side diff housing locktab when I torqued past 20 ft lbs!! I guess they don't make them like they used to  :(  Sent back to Mini Spares for a refund. RHS was fine when torqued up.
MMP
#5 Spider
  • 14,879 posts
Posted 30 November 2023 - 05:16 PM
I stopped using locktabs years ago. They are too soft, as you've found here, though that's a bit extreme. Those currently available (or at least last time I checked) are too soft, any 'goodness' done by torquing them up correctly is lost usually over the hours following that torquing as the locktab oozes out from under the fastener.
#6 Steve220
Steve220
  • 5,047 posts
  • Local Club: BMC
Posted 30 November 2023 - 08:09 PM
Bin the tabs unless you're going concourse! Threadlock FTW!
#7 Java_Green
Java_Green
  • 170 posts
Posted 30 November 2023 - 09:18 PM
What do you use instead or do you just run without?
#8 Spider
  • 14,879 posts
Posted 30 November 2023 - 11:10 PM
No doubt it'll be frowned on by some, but a decent flat washer and a decent spring washer, tighten to torque.
I know some may frown on my using a flat washer but without it, the spring washers do chew in to the castings, especially the alloy ones.
In the 20 odd years I've been doing them this way, I've never had anything come loose.
#9 Java_Green
Java_Green
  • 170 posts
Posted 01 December 2023 - 10:21 AM
That was what I thought. I agree that a spring washer needs a steel washer underneath to prevent "Al thewing" and to make use of torque spec (Al thewing will make friction go sky rocket and nothing left for pretension). Then their can always be a discussion about the usage of spring washers, but that is already discussed.
#10 Myminiproject
Myminiproject
  • Just Joined
  • 22 posts
Posted 01 December 2023 - 12:13 PM
Thanks Spider and Steve220. I've just torqued the bolts without washers, I guess I should add the washer and spring washer and threadlock and padlock  :D
#11 Cooperman
  • 23,287 posts
Posted 01 December 2023 - 05:04 PM
I jut use flat washers and Loctite.
#12 Gaz66
Gaz66
  • 909 posts
Posted 01 December 2023 - 07:03 PM
What thread lock are people using on these bolts, the blue stuff?
#13 Cooperman
  • 23,287 posts
Posted 01 December 2023 - 10:33 PM
Yes, that's the stuff.
#14 GraemeC
GraemeC
  • 7,438 posts
Posted 02 December 2023 - 08:12 AM
I use threadlock and Schnorr washers
#15 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 05 December 2023 - 08:59 AM
243
