Horn Not Working - Rotary Coupler? 2000 Mpi
3 replies to this topic
#1 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 23 September 2013 - 05:20 PM
Evening all,
Just been out to try to diagnose my lack of horn.  I do not have 12v at the horn on the purple/black wire (when the button is pressed).  I have removed the steering column cover, and removed the multi plug from the rear of the rotary coupler - I have got 12v at this point (purple/black) and I have got an earth on the black wire.  when plugged into the coupler, and the horn pressed, no voltage leaves the plug.  Do I need a new coupler?  The SRS airbag light is functioning correctly.  Is there any "contact points" I can clean when the coupler is removed?
With the multi plug removed, and I earth the purple/black wire, the horn sounds. So all wiring from inside to the horn is ok, plus the horn relay itself is ok.
Also, what kind of bolt / screw holds the airbag?
Ryan.
Photo 1
Photo 2
Edited by L400RAS, 23 September 2013 - 05:25 PM.
#2 100ev8
100ev8
  • 622 posts
Posted 23 September 2013 - 05:53 PM
2 x torx
#3 L400RAS
L400RAS
  • 2,479 posts
Posted 23 September 2013 - 05:56 PM
2 x torx
Cheers !
#4 L400RAS
L400RAS
  • 2,479 posts
Posted 28 September 2013 - 11:43 AM
Afternoon all,
Got it fixed; it was the rotary coupler / squib. I got one from a MG breakers off of a MG TF if anyone else needs one. It was the (later) part number YRC100300
