This isn't the composite Vs copper question.
I have recently seriously blown through a fire ring using a composite gasket so am now considering a cometic all metal gasket to stop this happening again.
They come in various sizes and the US company have asked for the bore size. Now as i didn't build the engine, rather had a machine shop do it i will give what i know and let the boffins feed back.
The engine is a 1330 with 21513 pistons running a Morspeed Ph3 Can, fully lightened bottom end and a BMC Works head.
The standard composite HG I removed measured 0.91mm which is around 0.36 thou?
From memory the machinist said he machined the block 0.15 thou and the pistons to match.
So would i be right in thinking i need a 0.51 thou Cometic gasket - or could I get away with a 0.40?
The reason I ask is Burton Motorsport have a 0.40 gasket in stock, 0.45 is 4-5 weeks and 0.51 is 8-14 days.
I want my mini back but don't want to kill it!
Edited by Wilson1330, 23 September 2013 - 07:43 PM.
