Is There Any Way Of Telling What Engine My Spi Has?
5 replies to this topic
#1 richardjackson99
richardjackson99
  • 28 posts
Posted 26 September 2013 - 10:04 AM
I own a 95 Sidewalk, which in theory has the milder tuned Spi lump. I know it was completely unmolested before I got it (I'm the 2nd. owner, and I knew the 1st.). The thing is, it "goes like grit off a shovel!" and I remember reading somewhere that sometimes the Cooper engine was dropped into non-Coopers when there was a shortage.
In its untouched state, it would easily top 90 ( also measured against my other car's speedo & my sat nav), now with nothing more than a Maniflow system ("Y piece" back) and de-cat pipe, I've had 100+. Surely not from a 53bhp lump? Obviously none of this on the UK public highway.
Any suggestions, other than stripping it down, would be gratefully received.
Many thanks.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 26 September 2013 - 10:30 AM
I used to work in a Vauxhall dealership and you could drive 10 Astras all brand new and all the same make, except 1 maybe 2 would go like the next engine size up, down to production tolerences and everything being right. One of the 10 would struggle to pull the skin of a rice pudding though. Either you have a different spec engine or a really good one. Have you put the engine number in the Guessworks website and see what it says.
#3 firstforward
firstforward
  • 824 posts
Posted 26 September 2013 - 11:02 AM
Mine is the same standard SPi but it will fairly quickly get to 90 (for a 53bhp) 83 on Sat Nav. Thing is at the speed the engine sounds sweet at about 4,250rpm ish
#4 richardjackson99
richardjackson99
  • 28 posts
Posted 26 September 2013 - 11:03 AM
I haven't, never heard of that site - will give it a go. Many thanks.
#5 cal844
cal844
  • 9,624 posts
  • Local Club: TFMOC
Posted 26 September 2013 - 11:05 AM
here is the link to the required page
http://www.guess-wor...Tech/engine.htm
my engine number starts 12A 2BG03
12A goes in the top box (CC and Orientation)
2B goes in the 2nd box (Engine Code Prefix)
G03 goes in the third box (Engine Code)
and the last 6 digits go in the bottom box( Engine Serial Number)
and here is the results for my engine
 Details
Source Vehicle :  Mini  Engine type & CC :  A+ 1275 cc Transverse mounted  Fueling :  HIF38 MAC10031, AEM Needle, Red Spring  Engine features :  9.4:1 Compression Ratio Gearbox features :  Std. Ratio Rod Change gearbox with Pot Joints
which is spot on! thanks Guess-works
Edited by cal844, 26 September 2013 - 11:06 AM.
#6 firstforward
firstforward
  • 824 posts
Posted 26 September 2013 - 11:18 AM
Am I missing some posts here?
