Benefits Of Having An Accuspark A+ 59D Distributor?
12 replies to this topic
#1 crf150
crf150
  • 555 posts
Posted 27 September 2013 - 08:39 AM
As it says in the title, what are the benefits of fitting an Accuspark A+ 59d distributor
Does it really make a lot of difference ?
no maintenance required ?
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 27 September 2013 - 08:45 AM
you'll be hear tales of increased performance and fuel effiency and better starting.
But I would say thats because people often compare worn out old parts to a brand new part.
Yes there is less maintenance, no points to adjust. its basically set it up and leave it. Just the usual parts like rotor arms and dizzy caps and leads to worry about.
Some people also claim wet weather misfires are cured, didn't notice it, still had to use a weather shield.
#3 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 27 September 2013 - 02:38 PM
mine gets used every day, i'd say go for it, just avoid deep puddles....
#4 crf150
crf150
  • 555 posts
Posted 27 September 2013 - 03:28 PM
i think im going to try and avoid any puddle ! :lol:
Does it really make much of a difference though? I dont want to buy it if its just 'ok' and makes it run a 'bit' better, if you can really tell a difference, like running conditions, starting etc. then i will get it.
is it simle just take the old dizzy out and put that one in ?
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 27 September 2013 - 03:33 PM
it should be in theory remove old and put in new, remembering you will need to reset the timing.
BUT there have been a couple of topics on here where people have had problems after fitting, starters spinning slow , weak spark...the cause seeming to be voltage drops but I don't recall anybody getting to the bottom of why
The othe option if there is nothing wrong with your dizzy, is replace the points with a Britpart kit for about £13...basically same module you get in an accuspark dizzy, just fitting it to your old case
#6 crf150
crf150
  • 555 posts
Posted 27 September 2013 - 03:46 PM
Britpart kit? have you got a link ?
#7 lrostoke
lrostoke
  • 6,923 posts
Posted 27 September 2013 - 04:01 PM
http://www.paddocksp...tronic-kit.html
http://www.mm-4x4.co...-kit-2721-p.asp
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 27 September 2013 - 05:17 PM
The biggest thing is reliability, from the moment you put new points in its a down hill slide until you get starting problems, electronic trigger and it maintains the setting through out.
Edited by KernowCooper, 28 September 2013 - 11:07 AM.
#9 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 27 September 2013 - 06:17 PM
I fitted the powerspark conversion in place of points.
Best thing I've done.
...... It will fail now. Lol
#10 tractor
tractor
  • 662 posts
Posted 28 September 2013 - 07:05 AM
I'd go with irostrok's suggestion, I did it a little while ago and it's quiet easy to fit and so much easier to maintain
Trac
#11 tractor
tractor
  • 662 posts
Posted 28 September 2013 - 07:09 AM
Just have a look and see if you've got a balest ignition or not, it'll make a difference to how you wire the modules mentioned above in.
The loads of topics on here that explain it better than I can
Trac
Edited by tractor, 28 September 2013 - 07:09 AM.
#12 tom1
tom1
  • 323 posts
Posted 28 September 2013 - 07:28 AM
What are thay like at high revs, in race engines ?
#13 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 28 September 2013 - 11:09 AM
Better setup and don't suffer from points bounce and a more reliable spark at high revs, But for race use I'd be using the aldon Igniter its the original and better quality control
Edited by KernowCooper, 28 September 2013 - 11:09 AM.
