Hif44 Carburettor With 1000Cc Engine?
4 replies to this topic
#1 siukeong
siukeong
    Just On Tickover
  • 9 posts
Posted 29 September 2013 - 06:59 PM
Dear all Mini Fans,
Currently i think to upgrade my carburettor to HIF44, it is can match with 1000cc engine?
HIF44 carburettor compatible with 1000cc engine? got any side effect?
Thanks and regards,
YONG
#2 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 29 September 2013 - 07:02 PM
An HIF44 may be oversized to use on a 998c engine and you may lose out on low down torque. It will also be a pain to set up. Personally I'd recommend using a single HS4 carb instead
#3 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 29 September 2013 - 07:06 PM
I'm not sure why you would want to put a HIF44 on a 998 as it wouldn't increase performance because of cylinder head limitations.
As Iain says, a single HS4 or HIF38 would suffice.
There's lots of threads on TMF about different carbs on 998s, so if you do a search you will find out much more information.
Edited by HarrysMini, 29 September 2013 - 07:14 PM.
#4 OfMini&Men
OfMini&Men
  • 284 posts
Posted 29 September 2013 - 07:13 PM
Hif38 if you want a more modern carb on it
#5 siukeong
siukeong
    Just On Tickover
  • 9 posts
Posted 30 September 2013 - 04:27 PM
HI,
Thank you for the answer and suggestion.
:D
