Japanese Post 97 Mini_Engine Block Number
3 replies to this topic
#1 edwardlam
edwardlam
  • 10 posts
Posted 30 September 2013 - 06:14 AM
Hi everyone,
anyone owned the japanese model post 97 mini with aircon model in here??or had experience for it.?
Japanese post97 rover mini 's spec is different to normal post97 model in UK. Its engine is not traditional MPI engine.  it is Spi head ,inlet, spi ecu and side radiator(simialr as normal spi engine layout) but with coil pack distributor similar as MPI model distributor.
Anyone know its short engine block model number?
is it same as MPI short engine block ?
ENGINE BLOCK CRANK AND RODS BUILT UP FOR TWINPOINT ONLY    LBB109100N
http://www.minispare...rch/classic/mpi engine.aspx|Back to search
THANk YOU
Ed
#2 dp0352
dp0352
  • 14 posts
Posted 25 October 2013 - 09:30 AM
Ed,
I own and drive a 1998 Japan Spec MPI Mini, with everything laid out as in the picture above.  If you'll tell me where to find the number you're looking for, I'll check it out and get back to you.  I've only recently purchased the car and this is my first Mini, otherwise I'd probably already know where to look.
Pete
Edited by dp0352, 25 October 2013 - 09:30 AM.
#3 mikespicooper
mikespicooper
  • 51 posts
  • Local Club: cyprus mini club, CMCT
Posted 25 October 2013 - 04:37 PM
Is it an auto one? autos have different engine model.....spi even japan spec ones are 12A2EF77!
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 25 October 2013 - 05:12 PM
It's an MPi short block, I know for certain that the auto's don't have a cam sensor, I think this is the same for the manuals.
