Mg 1275 Into 998
4 replies to this topic
#1 germini30
germini30
  • 699 posts
Posted 30 September 2013 - 12:27 PM
Yesterday I started stripping the mg metro down. It has been stood inside for years ztill in the original car. I drained the radiator and removed the other items such as starter and alternator. My mate said to try turning the engine over and it turned easily. The only thing I have noticed is that the water pump doesn't have a bypass hose so what is the best way to sort that. Also I want to get a payen headset but apparently there are two types depending on whether I want the head gasket with oil feed grommet or without. I am also planning on changing the valve stem seals and crank seals etc. Any tips on this conversion would be great.
#2 racingbob
racingbob
  • 3,061 posts
Posted 30 September 2013 - 01:22 PM
you say no bypass on water as far as I can see either change it or block the head
I have no bypass on my mg metro
I use bk450 seems good head gasket
you can buy the mpi valve seals or some standard, mpi is better and expensive
I don't have any stems on my exhaust
#3 DannyTip
DannyTip
  • 1,020 posts
  • Local Club: A Series Magpies
Posted 30 September 2013 - 01:28 PM
If you want to run it without the sandwich plate under the thermostat housing drill a few holes around the rim of the thermostat which does the same job as the bypass hose.
As for head gasket as above i use a BK450 on my MG Metro unit.
For valve stem seals the MPI viton ones are supposed to be best if a bit more pricy: http://www.minispare.../LJQ101160.aspx
Edited by DannyTip, 30 September 2013 - 01:30 PM.
#4 germini30
germini30
  • 699 posts
Posted 30 September 2013 - 02:35 PM
Yes working in a motor factors does have its advantages. I will get a payen headset with the for mentioned gaskwt in it.
#5 germini30
germini30
  • 699 posts
Posted 30 September 2013 - 03:38 PM
Do I use tge mg metro exhaust manifold or stick to my cooper freeflow.
