1986 Mini - 1293Cc, Coil Spring, Customized, T&t
9 replies to this topic
#1 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 02 October 2013 - 01:46 PM
Probally missed some details here, so any q's just ask.
Heres the details
1986 Mini City E
MOT till Feb 14
Tax till Oct 13
Body
Good shell with deseamed front and rear bumpers. Had a repair to the door step, OS Door reskinned and a OS A panel before a fresh coat of paint in September 12. Seems solid with no visible rust marks. Painted in kawaski green (the lime colour) with black additions. Sportspack arches. Black door mirrors. Powder coated black grill, headlight rings, no.plate light. New windscreen from minispares. All new window rubbers and filler stripes all round. Climair wind deflectors fitted etc. It is very solid, subframes excellent etc. Tow bar fitted.
Engine
1275cc A-Series bored 20thou to 1293cc
Stage 3 cylinder head, BK450 head gasket
Kent KC800 camshaft
Duplex timing chain
Verto Clutch
3.1 Final Drive, with rebuilt diff
HIF44 carb, LCB manifold, Alloy inlet, K&N cone filter
RC40 Twinbox exhaust system
Electric fuel pump
- Engine was rebuilt in late december 2012 when changing diff final drive ratio. Painted in lime green and black and has only covered a couple of hundred miles since. Oil pressure very good, consistant etc.
Interior
Head lining sprayed black by previous owner.
Custom Dashboard - Black flocked dashboard with 3 aux gauges (vacuum, oil pressure, voltage) and 110mph mini clocks with aftermarket lighting kit.
Front speakers fitted in dashboard.
Rear speakers fitted on a raised custom fibreglass speaker shelf.
Black leather seats from fiat coupe in the front, with black leather/vinyl look rear seat to match.
Black door cards with alloy handles.
Black carpets with closed cell foam underlay.
NEW Rear arch vinyl trims included but not yet fitted.
Carbon fibre look gear stick gaiter, chrome gearknob.
Electrics
Mostly rewired engine bay due to old fragile loom. New wiring run in and cloth wrapped as per a modern car.
Seperate blade fusebox for all aux devices, shows when a fuse is blown etc.
Sony CD/AUX/MP3/Radio wired in under dash, using correct ISO plugs so you can upgrade "plug n play".
RipSpeed speakers in the dash. JVC speakers at the rear.
Double 12v sockets (for charging phone etc)
Alarm fitted with interior sensors, shock sensors etc.
Wipac AUTOPAL headlights, halogens.
Also high beam spots in grill.
Alot of new electrical items including aux fuse box, standard fuse box, starter relay, flasher relay, wiper motor, front headlights, front indicator units, fuel pump etc.
Suspension/Brakes
Regularly greased in my ownership.
MINITASTIC coil spring conversion, fast road type. Adjustable height.
GAZ lowered adjustable shock absorbers.
All new knuckle joints all round.
Service items including rebound buffer, balljoints etc.
8.4" disc brakes up front, spacered drums at rear. Fairly new discs and pads (ebc black stuff pads).
Track rod ends fairly recent.
Front tie bars replaced and half poly/half rubber bushes used.
Wheels and Tyres
12x6 minilite style alloys.
Front semi deep dish, rears deep dish.
Fitted with a matching set of recent Falken tyres (the new type, not fk06...)
Finished in black, chrome nuts. No centre caps on the front.
Green dice valve caps.
Pics.... top 2 most recent.
1186771_10153213025750647_368736883_n.jp
1004853_10153141026780647_515259625_n.jp
318814_10152803987945647_1815718106_n.jp
407130_10152803987630647_1146970892_n.jp
Im away this weekend, but can sort out some more recent picutres next week.
Located in North East England.
Tax and tested, drive away....
Looking for £3250 or near offer
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 02 October 2013 - 03:29 PM
1234272_10153327915365647_800831005_n.jp
1237064_10153327913880647_2105484840_n.j
#3 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 06 October 2013 - 03:53 PM
bump
offers?
gunna break it for parts otherwise.
#4 BlackJester
BlackJester
  • 181 posts
Posted 06 October 2013 - 05:57 PM
Price?
#5 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
its up there, £3250 or best offer
#6 leaky
leaky
  • 6,890 posts
Posted 12 October 2013 - 12:36 PM
Shame if you do brake it for parts as its a good looking car but if that happens can you pm me a price for the engine? Cheers.
#7 bigken
bigken
  • 11 posts
Posted 12 October 2013 - 06:36 PM
where did you get your gauges they look great  :proud:
#8 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 12 October 2013 - 06:39 PM
they are 110mph mini clocks with an EL DIAL illumination kit. changes from green to blue using a switch, aswell as dimmer on them too.
#9 deakin1988
deakin1988
  • 116 posts
Posted 21 October 2013 - 07:47 PM
Hi do you still have the mini for sale
thank you
#10 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 21 October 2013 - 07:50 PM
Yes i do.
