"falling Through" Idle
3 replies to this topic
#1 Zik
Zik
  • 80 posts
Posted 03 October 2013 - 03:01 PM
Hi all, been having some trouble with a spot of rough running today. Car is an 87 Mayfair and the engine is pretty much standard with an hs2 carb.
The engine idles fine on start up, but after a couple of minutes driving if I depress the clutch, the revs will fall down and not be caught by the idle, and drop to 0. The engine also starts struggling if I decelerate with it in gear, if I'm pulling up to traffic lights the engine starts feeling very laboured below 2k rpm and I can feel the engine slowing the car dramatically. I've checked and the spark plugs are a good tan colour and tve gaps are correct. I gave the dizzy a wipe inside, a spray of wd40 and another wipe, but the 4 points look quite marked and a little past their best. I'm assuming this is an ignition problem not fueling as the engine runs fine above 2k or so rpm.
Colour me confused!
#2 jaydee
jaydee
  • 8,565 posts
Posted 03 October 2013 - 06:37 PM
An 87 mayfair will have an HS4 carb.
Looks like you have some breather disconnected, like engine breather to the carb.
#3 Zik
Zik
  • 80 posts
Posted 03 October 2013 - 07:06 PM
The carb has the diagonal bolt pattern of an hs2, according to the HBOL, only 2 mounting bolts. You know that might be spot on as the tapper cover breather hose is split quite badly at one end. I'll give replacing it a shot
#4 Zik
Zik
  • 80 posts
Posted 03 October 2013 - 07:12 PM
Apologies, Google has just informed me I do have an hs4, Haines lied to me! :o
