Jeting A Weber 45 Dcoe
5 replies to this topic
#1 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 07 October 2013 - 10:06 PM
hi ive got a weber 45 on a derrington manifold. the current set up that comes with the weber is
choke 36mm
main jet 175
air corrector 170
emulsion tube f2
idle jet 50 f9
pump jet 55
aux venturi 3.5
needle valve 225
my engine spec is
1380cc
ported big valve head
kent 276 cam
lightened flywheel
10.5.1 compression
all balanced end to end then all together
if you could give me some advise that would be great. i know it will need a rolling road set up but i could do with running it in before hand and i don't want to be trying to run an engine in with the wrong jets :D
cheers
bear.
#2 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 08 October 2013 - 07:10 PM
bump
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 09 October 2013 - 03:02 PM
I can only give you what I have on file, but its only a starting point.
Have you run it at all before?
36mm chokes
F2 Emulision Tubes
4.5 aux Venturies
160 main jets
180 air corrector
45 acc pump jets
45 F9 idle jets
Edited by KernowCooper, 09 October 2013 - 03:03 PM.
#4 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 09 October 2013 - 06:16 PM
cheers pal!!
no  its not been run yet, in fact the engine isn't together yet.
what would it currently be jetted for then?
bear.
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 10 October 2013 - 12:10 AM
Set up now looks like the motor needed a bit more fuel, possibly something with a wilder cam but because engines vary it is set richer than my base settings, which could be to rich for your spec, its never a good idea to run a new build to rich due to bore wash
#6 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 10 October 2013 - 03:54 PM
cheers pal! and thanks for sharing your knowledge :D
