Toeboard Reinforcement
6 replies to this topic
#1 Jonansen
Jonansen
    Starting My Mini Up
  • 2 posts
Posted 09 October 2013 - 11:25 AM
Hi
I'm going to solid mount the front subframe and I know I have to reinforce the toeboard, but when I removed the carpet there allready was some plates. But I'm in doubt about it's enough.
I attached a foto and hoping somre of you can give it a go pr no go.
by the way it's a 1976
#2 tiger99
tiger99
  • 8,584 posts
Posted 10 October 2013 - 11:48 AM
You need somewhat larger and thicker plates, say 2mm by 6 inches square.
#3 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 10 October 2013 - 04:31 PM
One side, both sides, attached or free floating ?
#4 rally515
rally515
  • 3,848 posts
Posted 10 October 2013 - 04:37 PM
Looks like a leter subfrme and shell than 76', although that was a crossover year so i'm guessing its just a later 76 mini
As has been said, usesome think steel and make two plates to weld over the area (with bolts removed), then drill the holes out, paint and bolt it all back up and jobs a gooden. :)
Make sure you protect with plenty of paint and plug weld also as welding around the edges isn't that great.
Some i,ve seen were one big piece across and over the tunnel so might be an idea if you,re feeling more technical :P
#5 4l1x
4l1x
  • 27 posts
  • Local Club: Basingstoke
Posted 10 October 2013 - 07:43 PM
This is what I have done and as said jobs a gooden
Edited by 4l1x, 10 October 2013 - 07:44 PM.
#6 tiger99
tiger99
  • 8,584 posts
Posted 11 October 2013 - 09:31 AM
rally515's idea is a good one, especially if the outer sides of the plate join up with the wheel arch, as not only will it stiffen the subframe mounts but it will strengthen the area of the Mini that often collapses in a hard frontal impact, resulting in trapped and severely injured feet. So you gain on safety, for a bit more work. Some more metal welded to the flat floor, and to the main stiffner, along the floor to toeboard seam would make it even stronger in a crash.
#7 Jonansen
Jonansen
    Starting My Mini Up
  • 2 posts
Posted 26 October 2013 - 10:44 AM
Thanks for the replys :)
