I have a 2010 Cooper S. It's been knocking for some time now in the enigne, but over the past week when i started it in the morning when cold, it has died as though the automatic choke was dying. The car drinks oil through the turbo, so it could relate to that. Today i changed the timing chains and the knocks still there. If you press your ear to the sump when its running it sounds like the knock is coming from inside. Is there an oil pump in there which is likely to be broken? The car now sounds worse with the new timing chains in it. The car starts ok now, and the chains were fairly bowed when I took them out, so i think that the starting issue was because it keeps running low on oil as i dont always check it (every week) and it drinks oil like its going out of fashion so the tensioner became loose through lack of oil.
I have only changed the chains, not the top sprockets someone has suggested that the larger of the sprockets could be worn?
Has anyone else had this issue?
Rob
