Starter Motor Solenoid Trouble
7 replies to this topic
#1 Cjbagnall
Cjbagnall
    Just On Tickover
  • 6 posts
Posted 13 October 2013 - 03:29 PM
The main connection on the solenoid is all wobbley,. The car starts when I press the connection down with a screw driver but doesn't without. I've been told I'll need a new starter motor, is it possible to fix it or shall I just get a new starter. Cheers chris
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 13 October 2013 - 03:32 PM
What starter are we talking about? inertia or pre-engeaged, if its where the cable connects on the inertia then you can buy spare parts as reqyuired and the same for the later type, depends how old the starter is and what the rest is like when you check it over
Ring Mini Spares or failing them Someford Mini they keep lots of electrical repair parts
Edited by KernowCooper, 13 October 2013 - 03:34 PM.
#3 Cjbagnall
Cjbagnall
    Just On Tickover
  • 6 posts
Posted 13 October 2013 - 03:55 PM
It's a pre engaged I think, the solenoid is connected to the starter. It's an 86 Mayfair 998 thanks
#4 Ethel
  • 26,580 posts
Posted 13 October 2013 - 04:54 PM
The threaded connection posts are the solenoid contacts at the other end. You can strip it down & find service parts on eBay etc.
#5 Cjbagnall
Cjbagnall
    Just On Tickover
  • 6 posts
Posted 13 October 2013 - 05:13 PM
I think it's the other connection the male spade connection
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 13 October 2013 - 10:29 PM
I don't work on any cars that have the pre-engaged starter but from looking at parts diagrams I thought the entire pre-engaged starter solenoid could be replaced as a unit?
#7 Ethel
  • 26,580 posts
Posted 13 October 2013 - 10:45 PM
It can, if it's the operating terminal  (red/white or red/brown wire) you might get lucky with a soldering iron if it's just a dry joint.
#8 Cjbagnall
Cjbagnall
    Just On Tickover
  • 6 posts
Posted 14 October 2013 - 05:56 AM
Thanks, I'll look into getting one or maybe the soldering iron. Found this happy chappy changing one http://m.youtube.com...h?v=Af-SxRROHzA
Edited by Cjbagnall, 14 October 2013 - 06:10 AM.
