Knuckle Joints
3 replies to this topic
#1 patricksouth
patricksouth
  • 298 posts
Posted 18 October 2013 - 02:37 PM
hi i have hilos already fitted and need to replace the knuckle joints as it failed the mot on the fact the rubber boot is split i already have the knuckles but want to no if i can replace these without the compression tool.....
cheers
#2 Tupers
Tupers
  • 4,156 posts
Posted 18 October 2013 - 03:14 PM
You may be able to wind the Hi-Lo all the way in and allow the knuckle to be removed without a compression tool. It really depends on how worn you cones are already though.
#3 patricksouth
patricksouth
  • 298 posts
Posted 18 October 2013 - 03:18 PM
ok so it is possilble then will have a look tomorrow and see how i get on
#4 Ethel
  • 26,064 posts
Posted 18 October 2013 - 04:56 PM
Get some M14 threaded rod, nuts & big washers, it may well do enough. screw it in while it's sat on its wheels & it may not even need compressing: with the Hi Lo's wound up & rebound stops removed.
http://www.theminifo...ne-thread-size/
