What's The Torque Setting For Arp Con Rod Nuts (1275)
Posted 20 October 2013 - 11:47 AM
Iv been told to use lots of oil to torque the nut up a I don't have arp lube but the arp stuff is like a grease not an oil will it still be okay to use oil
Posted 20 October 2013 - 11:50 AM
Look in a haynes manual?
Posted 20 October 2013 - 12:04 PM
Posted 20 October 2013 - 12:15 PM
IIRC, ARP state to do them to 28 ft-lbs. Although someone will need to confirm.
I know it's definitely less than standard con rod nuts.
Edited by HarrysMini, 20 October 2013 - 12:15 PM.
Posted 20 October 2013 - 12:27 PM
Its annoying no one is open to ring and ask I'm sitting here waiting to fit them and can't because I can't find an awnser
Posted 20 October 2013 - 02:52 PM
Okay, just had a chat with a mate who has the ARP bolts. He says it is 26 ft-lbs using the ARP moly grease.
ARP have a specific way of torquing the nuts as well; I think you have to tighten, undo and retighten each bolt three times.
There must be someone on here who has ARP bolts who can confirm what I have said.
Posted 20 October 2013 - 04:44 PM
Enter your ARP kit number on the link and it tells you the torque setting (under Instructions) http://www.arp-bolts...nstructions.php
Posted 20 October 2013 - 06:09 PM
And it tells you everything about arp bolts on there site an has nothing about how you tighten up in sequence
Posted 20 October 2013 - 06:26 PM
depending what size you have ARP suggest - http://arpinstructio...ns/206-6002.pdf
if you have a read through their site all the info is available http://www.arp-bolts...nstructions.php
Posted 20 October 2013 - 06:57 PM
Posted 20 October 2013 - 06:58 PM
