Sw5 Vs Kent 276
Posted 20 October 2013 - 05:44 PM
Posted 20 October 2013 - 05:49 PM
SW5 is milder than the 276 which I run in my 1330, idles a bit lumpy at 1000rpm, pulls ok in traffic and not disappointed with mine.Whats the rest of your engine spec ?
Posted 20 October 2013 - 05:55 PM
Posted 20 October 2013 - 06:32 PM
Had a 276 in last mini very similar spec to yours I was happy not hard work around town but pulled well when I wanted. tick over a little lumpy. never tried a sw5 .
Posted 20 October 2013 - 08:18 PM
Timed at 106Degs
Posted 20 October 2013 - 08:24 PM
Posted 20 October 2013 - 09:04 PM
None on mine stg4 head,276, Aldon Yellow, 10.2:1, Maniflow LCB/Single Box and CO = 3.5% and 600ppm
Posted 26 October 2013 - 02:21 PM
Hi Mini Mad,
If you do decide to change cam I would be interested in buying the SW5 off of you. I sent you a PM on monday.
Posted 27 October 2013 - 10:40 AM
Ok the SW5 and the 276 cam are two completely different beasts. The 276 has more than twice the overlap lift for a start so the power bands are very different. It a bit like comparing apples with peebles!!
AC
Posted 27 October 2013 - 01:47 PM
Do you prefer marmalade or marmite?
Edited by jaydee, 27 October 2013 - 01:47 PM.
Posted 27 October 2013 - 05:47 PM
What your saying is something smother, or something with a bit of bite
Posted 27 October 2013 - 06:22 PM
AC beat me to it - comparing the two cams directly is unfair as they are designed to do different things.
The SW5 is a big improvement over standard, and makes for a nice smooth driving cam that gives you a wall of torque.
The 276 is pretty much the first of the 'hairy' cams and designed for higher rpm use at the expense of all round driveability.
