As the title can anyone help me with the technical data for this camshaft. I`m looking for something close to a 997 cooper cam to use on a 998 engine and I have this one on a spare motor? Thanks.
Posted 21 October 2013 - 05:10 PM
Posted 21 October 2013 - 07:37 PM
The Piper HR270 has more timing and lift than the Cooper 997 cam.
Cooper 997 timing 16/56 51/21 (252 inlet & 252 exhaust) with 250 thou lift at cam lobe
Piper HR270 timing 22/62 64/28 (264 inlet & 272 exhaust) with 284 thou lift at cam lobe
Piper HR270/2 timing 28/64 64/28 (272 inlet & 272 exhaust) with 284 thou lift at cam lobe
See page 254 of Vizard's 'blue bible' for example HR270 power curve in a 998, comes on cam from 2000 rpm. DV also mentions that if you use this cam with high lift rockers in a 998 then you will lose up to 7bhp in the lower rpm range.
Posted 21 October 2013 - 08:15 PM
Thanks for that. I have the yellow bible and it does not show anything on Piper cams, is it a good cam for the 998 and could you please tell me the full inlet degrees? Thanks :)
Posted 23 October 2013 - 04:51 PM
Anyone ?
Posted 24 October 2013 - 07:12 PM
Bump
Posted 24 October 2013 - 07:34 PM
I think I've got an old HR270 sat in the garage if you need one.
Posted 25 October 2013 - 06:02 PM
Thanks but I have one. I just need to know the full inlet degrees after TDC to time it in and if its any good for a sensible 998 motor rather than a screamer. I`m guessing its more suitable for a 1275 motor but it would be nice to hear from someone that has used one on a fairly tame 998 with a standard air box, cleaned up 12g202, rc40 type of thing.
Posted 25 October 2013 - 07:44 PM
Sorry to hijack your thread but I'm building a similar kind of 998 engine with a 940 cylinder head and an MG metro cam, does anyone have the details for timing the MG metro cam?
Andy.
Posted 25 October 2013 - 08:37 PM
No worries, I can answer that one for you. The factory spec is Full inlet lift at 110 degrees after top dead centre :)
Posted 25 October 2013 - 09:50 PM
Suggest setting to 108 degs ATDC to allow for a 2 degree for initial chain stretch.
It should be a good cam for a 998, but use standard rocker ratio.
