Rubber Sill Trim
9 replies to this topic
#1 willava182
willava182
  • 704 posts
Posted 21 October 2013 - 10:51 PM
Well where can i buy the rubber trim that does on the sills between the two wheels.
(well probably every mini)
Thanks :P
#2 Earwax
Earwax
  • 488 posts
Posted 22 October 2013 - 04:44 AM
that looks like a variety of pinch weld: easily purchased from rubber shops.  i have no idea of the correct measurements though
#3 finch661
finch661
  • 2,339 posts
Posted 22 October 2013 - 07:37 AM
this by any chance?
http://www.minispare...lding.aspx|Back to shop
#4 tiger99
tiger99
  • 8,584 posts
Posted 22 October 2013 - 11:45 AM
It is normally plastic, rather than rubber (although there is no reason not to consider rubber), and available it at least silver and black, although steel (needs painting in body colour) and stainless steel trim strips are also available. There are thick and thin variants too. But you could fit almost any type of edge trim, if you want to be different. The only legal consideration is to cover the edge with something rounded, it doesn't count as a modification. It may be that somewhare like B&Q have suitable trim strips, intended for something quite different. You may even get one with a nice, colourful pattern. 40 years ago, accessory shops were practically full of non-standard Mini trim.
It may be a good idea, if using a metal trim with the spring clips, to fill the back of it with thick Waxoyl before fitting, as it frequently is a rust trap. For plastic or rubber, fill the groove with a body adhesive such as tiger seal to keep the water out. You could also glue on a metal trim, without the clips.
#5 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 22 October 2013 - 01:13 PM
My '91 Mayfair used the rubber trim as per the link above. I've not seen one with the plastic variety (yuck!).
#6 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 22 October 2013 - 02:10 PM
Pheonix trim(LINK)  is surposed to be very good for trim like that.
#7 TORZIEnJIM
TORZIEnJIM
  • 683 posts
Posted 22 October 2013 - 04:07 PM
+1
#8 willava182
willava182
  • 704 posts
Posted 24 October 2013 - 08:19 PM
http://www.minispare...DDJ10002MS.aspx
Looks like this is the stuff for me, seeing as my car is 93 :)
#9 willava182
willava182
  • 704 posts
Posted 25 October 2013 - 06:21 PM
Although Pheonix trim looks good i will go with them!
#10 RedRallyMini
RedRallyMini
  • 309 posts
Posted 25 October 2013 - 09:56 PM
I've bought mine here:
http://www.cbsonline...ge_Trims,b.html
