Hi everyone I need to replace my knuckle joints at the front. I have high low cones and adjustable suspension. How would I replace the knuckle joint? Would it be possible to wind the trumpet in enough to lift the cone out? Or would I need to compress the cone and take the cone out? When I'm replacing the knuckles do I need to take the weight of the whole front of the car or can I just do them one side at a time and just raise one corner at a time. Any replies are much appreciated
Replacing Front Knuckle Joint, With High Lows On?
babsbrown
, Oct 23 2013 07:18 PM
2 replies to this topic
Posted 23 October 2013 - 07:18 PM
Posted 23 October 2013 - 07:37 PM
You should be able to wind the trumpet down and pull it out and replace the knuckle joint. One side at a time would be fine.
I geuss you mean that you have hi-lo's and rubber cones and adjustable shocks?
Posted 23 October 2013 - 09:14 PM
ah brilliant, yea I have the hi-lo's and rubber cones but without adjustable shocks :) thats great to know i can just replace them without having to borrow a compressor tool!
