Jet Wash And Rust
6 replies to this topic
#1 profmatt
profmatt
  • 127 posts
Posted 24 October 2013 - 06:54 PM
I had my Mini cleaned by a jet wash company today. I noticed some alarming looking rust I hadn't seen before. (I'm attaching two photos: one was taken in the summer, the other today.)
How bad does it look to you? How easy is it to fix? How expensive?
#2 JimminyBob
JimminyBob
  • 384 posts
Posted 24 October 2013 - 06:56 PM
If it is rust and not a paint reaction then bad, the wing will need replacing eventually.
#3 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 24 October 2013 - 06:59 PM
Definitely rust. New wing and possibly scuttle corner if it has spread.
#4 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 24 October 2013 - 07:00 PM
thats rust and as probally been working its way through the panel for months.
new wing and possible scuttle corner / under scuttle panel too. check the air vent area and door post as they usually all start to go around the same time.
#5 SecretSugar
SecretSugar
    Sweet!
  • 508 posts
Posted 24 October 2013 - 07:11 PM
Looks like water has got behind it at some point making the area flake and rust quicker. Jet wash might not of helped. Wing and maybe new scuttle too.
#6 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 24 October 2013 - 10:05 PM
Never mind the rust, what on earth were you thinking of letting someone with a jet wash near a classic mini??  :o
It's a classic car, so wash it by hand with a quality car shampoo and a soft wash cloth. A high pressure jet wash is likely to strip paint, blast rustproofing away and get moisture into seams and other unwanted areas, making your corrosion problems worse.
#7 Cooperman
  • 23,328 posts
Posted 24 October 2013 - 10:12 PM
See if you can push a small screwdriver through the rust. If you can it will need a new wing. Poke at the scuttle panel with the same screwdriver. If it goes through a new scuttle panel end is needed.
AS for price, a genuine wing is c.£80, scuttle end would be c. £15. The screen has to come out to do a scuttle end. time is in the region of 4 hours for  cutting, welding and grinding back (assuming no more rust is found in the inner wing or front panel). The allow for re-painting wing & scuttle. Say around £275 for the whole job if no other rust is found.
