Hif44 Dashpot Oil?
Posted 24 October 2013 - 08:52 PM
Posted 24 October 2013 - 09:07 PM
You fitt the dashpot the same as the HS carbs. 3 in 1 is acceptable, but switch to something thicker if you get flat spots-boggin down under acceleration.
I use 15w40 with the HIF44, but oil choice is part of the carb tuning really.
Make sure the damper is the correct type LZX2085.
Posted 24 October 2013 - 09:41 PM
yes as above it all depends on what state of tune your mini is in.....my 1380 uses a HIF44 and I use 3 in one oil it responds realy well as piston rises a littke quicker than with engine oil........
Posted 24 October 2013 - 09:59 PM
3-in-1 is good, as is air tool oil.
Posted 24 October 2013 - 10:36 PM
I've always found 3-in-1 way too thin on a variety of cars from 850 to 1380 (and a Dolomite) and with an assortment of carburetion methods.
It's probably better to go a touch rich on what than too lean and bog down.
Posted 25 October 2013 - 06:34 AM
Posted 25 October 2013 - 06:58 AM
Posted 25 October 2013 - 09:30 AM
I use ATF
Posted 25 October 2013 - 11:01 AM
about 1/2" from the top yes I use 3 in 1 but have to top up regulary
Posted 25 October 2013 - 11:10 AM
i got 15w40 now as 3in1 was too thin
Posted 25 October 2013 - 03:21 PM
That's probably the excess being sucked into the carb
Posted 25 October 2013 - 03:41 PM
i had my 3 in 1 being spat out of the little hole in the top of the dashpot lid
Posted 25 October 2013 - 07:29 PM
Posted 25 October 2013 - 08:17 PM
http://www.minispare...ors/BDR125.aspx
I have used ATF in the past but dashpot oil is easy to get these days.
