A Few Questions About 998 997 Cams And Cranks Engine ?
9 replies to this topic
#1 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 25 October 2013 - 12:01 PM
Ok Ive a few questions id like some help with.
First of all cams and rings. identifying them.
Ive got a few cams lying around and would like to know what there from.
1> slot drive, 1/2 inch lobes, fuel pump lobe present, no rings.
I think its a standard      A plus 998cc ???????????
2> pin drive,  3/8 lobes, fuel pump lobe present, 1 ring
Im thinking 997cc cooper cam????????????
3> slot drive  1/2 lobes, fuel pump lobe present, 2 rings.
      mg metro ??????????
4> pin drive, 1/2 lobes, fuel pump lobe present, 3 rings  marked en32
 998cc cooper 731 ??????????
now the crank bit.
Well ive a box off bits that came in a deal a few months ago, was told it was a works 997cc engine but i took that with a pinch of salt.
Anyway
block is a 12a497  which i beleive to be a 998 cooper as its pre A plus. bored .020 with a main strap on it,  Its pre 1965, going on the old old style timing cover without the strengthening recesses
pistons are .020 d tops 3 ring
rods are 12g127
cam is the one ive spoke of above
Crank
en16
its been balanced at some point and the original numbers are missing, its be restamped aeg601, i cannot find anywhere what this is/ the stamping looks professional
what could it be???????????
my ideal is to use the engine but get the block pocketed so i can bolt on a 12g940 and mate it to a 1275gt c/r box i have
run it on a hif44 or a hs6.
which should make a reasonable fast road mini.
#2 Quincy Sparks
Quincy Sparks
  • 242 posts
  • Local Club: BHMC, MCR
Posted 25 October 2013 - 01:25 PM
AC Dodd posted some camshaft photos recently which might help with identification : http://www.theminifo...-identification
#3 carbon
carbon
  • 2,590 posts
Posted 25 October 2013 - 04:33 PM
The pin drive cam with 3 rings is 731, you can get these with 3/8 and 1/2 inch wide lobes.
Edited by carbon, 25 October 2013 - 04:34 PM.
#4 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 25 October 2013 - 05:09 PM
If it is MG Metro, it'll have a ¼" Groove in it. And yes it is slot drive and has the fuel pump lobe.
#5 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 26 October 2013 - 11:00 PM
block is a 12a497  which I believe to be a 998 cooper as its pre A plus
It'll be a 998 or 1098 block. A 998 Cooper block is the same as any other pre A+ 998 block.
#6 Ethel
  • 26,073 posts
Posted 27 October 2013 - 02:33 AM
Always be wary that a cam isn't a regrind when trying to identify it. I suppose it's less likely if the bands say it's something a bit more exotic, and you'll usually find the profile number stamped on the end if it has been ground.
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 27 October 2013 - 10:42 AM
Happy to run a camshaft workshop if people want to find out how to id and measure there own cams.
AC
#8 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 27 October 2013 - 10:50 AM
Asssuming not regrinds and they are factory originals;
Cam 1, Stock A+ 1275 profile.
Cam 3 A+848/998 low compression cam. 2 rings between lobes 3&4. Or A+ 1275 sprite cam 2 rings between lobes 7&8. Both these 2 cams work much better with 1.5 rockers installed even better on a 998. So, although seemingly stock a verry good choice for a fast road engine but must be used with 1.5 rockers to get it to work.
AC
#9 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 27 October 2013 - 11:15 AM
are you sure???
as some 998cc pre A plus blocks came with the mechanical fuel pumps so had the hole at the back.
this block is blanked off in the casting  as the coopers had electric fuel pumps????
#10 62S
62S
  • 1,243 posts
Posted 30 October 2013 - 08:20 AM
are you sure???
I've seen mid 1960's onwards 998 blocks with the hole for the petrol pump blanked off with a plate. Don't know why they would have had this as UK Mini's certainly didn't have the mechanical petrol pump at the time.
