No Inlet Manifold Vacuum Takeoff
6 replies to this topic
#1 Burgerdale
Burgerdale
  • 151 posts
Posted 28 October 2013 - 10:32 PM
Hi all,
Anyone know what to do if the intlet manifold has no vacuum takeoff?
Just got a new manifold and it doesn't have one.
Dale
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 28 October 2013 - 10:52 PM
Does the maniflod have a flat area, if so drill one and fit the adapter in, mini spares keep the adapter
#3 Ethel
  • 25,948 posts
Posted 29 October 2013 - 12:03 AM
For a brake servo hose?
As above if it's cast in, but not drilled, you could do that  yourself. The original fitting is 5/8 unf, you'd also have to flat the surface for the sealing washer. Either do that first with a file or use a counter bore, so that it's true with the thread. Alternatively tap it with a pipe thread, or drill a plain hole for an interference fit.
#4 Burgerdale
Burgerdale
  • 151 posts
Posted 31 October 2013 - 04:30 PM
Thanks ethel. Its not cast in, would need to drill but it has a flat section. Im assuming as long at the flat section can be drilled through to the airflow it'll be ok.
#5 Ethel
  • 25,948 posts
Posted 31 October 2013 - 04:46 PM
I did mean a thicker round bit cast for a fitting, but not  drilled & tapped. You'd be better off going for an interference fit, or 1/4bsp, with a taper threaded hose, tail if you're trying to do it without workshop tools.
#6 wurzel1974
wurzel1974
    Just On Tickover
  • 6 posts
  • Local Club: Somerset misfits petrol heads
Posted 07 December 2023 - 12:58 AM
Hello I have the inlet manifold with the hole in it, I’m looking for the part to put in there for a vacuum hose, but I can’t seem to find the correct one,
#7 Ethel
  • 25,948 posts
Posted 07 December 2023 - 08:57 AM
https://minispares.c...|Back to search
Don't forget the sealing washer
