hi guys im having a few troubles, basically i want to attach the A post stiffner to the A post but if i put them together and line the square and circular holes up then it puts the other side out and vice versa is there anything i can do to make them fit better,,,,,, thanks
A- Post Stiffner Trouble
Posted 29 October 2013 - 06:58 PM
Posted 29 October 2013 - 07:32 PM
I had to file the hole to fit it. Line it up an file the hole to suit.
Posted 29 October 2013 - 08:03 PM
sorry what i meant was the two panels dont fit together very well
Posted 29 October 2013 - 08:48 PM
You may have to do some trimming and panel beating to get them to fit nicely.
Posted 29 October 2013 - 08:55 PM
ok i thought so.... would you weld them together before fixing to the mini and should i plug weld them together or seem weld?
Posted 29 October 2013 - 09:07 PM
I would weld them in separately and by plug welding. Seam welding could potentially distort causing more issues.
Posted 29 October 2013 - 09:15 PM
as this is going to be my first ever repair can you give me a rough idea of how many plug welds would be ok is it still good to do them about every inch?
Posted 29 October 2013 - 09:18 PM
Yes one an inch will be good, just bare in mind though where you need to get in to grind them down.
Posted 29 October 2013 - 09:36 PM
will do thanks for your help
Posted 29 October 2013 - 09:40 PM
No problem.
