Heel Board Repair
15 replies to this topic
#1 Euan
Euan
  • 18 posts
Posted 29 October 2013 - 07:41 PM
Hi
Is there a repair panel available with the 2 captive nuts on it that the front of the back subframe bolts onto?
#2 Archived4
Archived4
  • Archived
  • 822 posts
Posted 29 October 2013 - 07:45 PM
Yes, I used an M machine panel to do my mini, both sides. great repair piece! about £14 I think!
#3 rally515
rally515
  • 3,848 posts
TADA:
http://www.minisport...te-genuine.html
#4 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 29 October 2013 - 07:47 PM
Yes
http://www.ebay.co.u...=item2562edc74a
#5 Minidarren83
Minidarren83
  • 1,207 posts
Posted 29 October 2013 - 07:48 PM
I would suggest this panel and use what you need off of it as it gas the captive nuts and inner sill stiffener attached
Obviously If you need the other side then buy the other half listed as subframe mount on minispares
Darren
#6 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,043 posts
or
http://www.minisport...duction-lh.html
Or make your own ;D
#7 Daz1968
Daz1968
  • 2,058 posts
Posted 29 October 2013 - 08:36 PM
I used m-machine ones and they fitted fine, I really rate their panels as good value and quality.
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,089 posts
  • Name: Neil
Posted 29 October 2013 - 08:44 PM
I really hate these ones as they are not all that good. You can buy a decent repair panel as already mentioned or you can make your own like this
you can buy the heelboard subframe mounting bracket from M machine
11.32.02.27 Bracket, Rear Sub Frame Mounting with captive nuts, LH 4.00 4.80
11.32.02.28 Bracket, Rear Sub Frame Mounting with captive nuts, RH 4.00 4.80
#9 Euan
Euan
  • 18 posts
Posted 30 October 2013 - 02:26 PM
Thanks guys 2 repair panels ordered from mini sport
#10 sonikk4
sonikk4
  • 16,089 posts
  • Name: Neil
Posted 30 October 2013 - 02:31 PM
When you get them add some extra weld to the captive nuts.
#11 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 30 October 2013 - 02:56 PM
I also have a full length panel in the garage but could not see the point of replacing the whole panel for the sake of rotten ends. When I got the car the PO had removed so much metal the heelboard was about the only thing keeping the car together.  :lol:
#12 Euan
Euan
  • 18 posts
Posted 01 November 2013 - 04:55 PM
Thanks I'll beef up welds.
Is there a problem with oversills, I've cut 2 off,it's a bit rotten underneath but I was just going to patch it up and put new oversills back on.
#13 alex-95
alex-95
  • 6,043 posts
Posted 01 November 2013 - 05:01 PM
If you are taking the old oversills off and replacing them, then get some proper sills or chop the oversills in half.
#14 sonikk4
sonikk4
  • 16,089 posts
  • Name: Neil
Posted 01 November 2013 - 05:30 PM
No don't put oversills back on. They are not correct and no matter what the arguments are for using them they will create problems.
Use the correct short sills and they will not cause your inner sills and floors to rust.
#15 corrado vr6
corrado vr6
  • 678 posts
Posted 01 November 2013 - 11:50 PM
And stop your mini from being de-valued due to oversills, as anyone in the know unless they are after a project will be put off buying a mini with oversills
