Injection Timing - Degrees
1 reply to this topic
#1 Dutchy1978
Dutchy1978
  • 24 posts
Posted 30 October 2013 - 02:24 AM
Hi guys,
I have injected my mini and am setting up the ECU. Does anyone know what the cycle is for injecting fuel into each cylinder on the intake stroke?
Keeping in mind the firing order is 1,3,4,2
I have set it up as per below but don't think it will be right as this is more the firing order degrees than fueling order degrees
Cyl 1   0 degrees
Cyl 2   540 degrees
Cyl 3   180 degrees
Cyl 4   360 degrees
Photo of the Autronics screen attached is that helps.
Any help will be appreciated.
#2 Dutchy1978
Dutchy1978
  • 24 posts
Posted 31 October 2013 - 04:52 AM
Made some mods. I moved the injection timing for each cylinder to be 210 degrees before the firing stroke.
ie: 180 degrees BTDC = intake stroke
210 degrees BTD = 15 degrees before intake (180)
Based on 720 degrees full cycle
Cyl / firing order       Firing degrees        Injection degrees
1                                        0                           510
3                                     180                          690
4                                     360                          150
2                                     540                          330
Thoughts?
Edited by Dutchy1978, 31 October 2013 - 04:55 AM.
