First off, I've done a search - getting conflicting answers. OAT for later engines?
My Mini is a '95 SPI.
This'll be it's first winter with me, so now is a good time to top on with fresh antifreeze.
However, I don't know what's in there at the moment - it's brown and watery, no sludge or anything. Is that the later brown/orange OAT antifreeze in there?
Thanks.
Oh No, Not An Antifreeze Question!
Posted 31 October 2013 - 02:59 PM
Posted 31 October 2013 - 03:10 PM
Posted 31 October 2013 - 03:25 PM
Sounds like you need to drain, flush & start again, Ethylene Glycol is the safe bet, though there is universal OAT that claims to be safe with copper & brass.
Posted 31 October 2013 - 03:46 PM
Thanks for the replies - looks like a trip to Halfords and a full flush is on the cards for this weekend!
This is what I found conflicting in my first search on the subject - there's comments saying it's fine and others saying it's been eating the copper inside MIni rads.
Posted 31 October 2013 - 03:55 PM
There are masses of different specs of OAT, I've started using Eurocarparts own brand in my diesel, so I'll let you know. With the (prior) state of my radiator it shouldn't take long, if there is an issue.
GL12+ seems to be the magic code - VAG's spec
Posted 31 October 2013 - 05:11 PM
I read only use blue and not to mix with red.
Posted 31 October 2013 - 05:34 PM
the mpis used the red and I use the red in all the mini's because the blue seems to attack the heater matrix because they are made of aluminium.
Posted 31 October 2013 - 08:03 PM
Posted 31 October 2013 - 10:11 PM
make sure you get stuff with bittering agent so animals won't drink any spillages if you have any
Posted 01 November 2013 - 09:13 PM
IAT is the one then, reading up on that Rolls Royce/Bentley site has made me fear OAT.
Posted 01 November 2013 - 10:38 PM
From the '96 Rover workshop manual:
"Use UNIPART SUPERPLUS 3 ANTI-FREEZE AND SUMMER COOLANT* to protect the cooling system.
Posted 03 November 2013 - 10:20 AM
I use HOAT for everything. Sell it to a half dozen dealers, (Mitsubishi, MB, Jeep, Nissan, and others) and hundreds of CAT motors.
Posted 03 November 2013 - 05:45 PM
Fernox S1, for Solar Heating, sounds interesting, only it degrades over 200 Celcius, I wonder how long it'd last in an engine?
Sounds like a challenge...
All done! Drained, rinsed through, IAT in. Will see how this goes.
Thanks all!
Posted 05 November 2013 - 09:41 PM
Uh i have the 'blue' stuff in mine with an alu rad, i should be ok.. right? =[
