3 Clock Backlight
Best Answer sherly , 06 November 2013 - 09:09 PM
Just done mine.
Used these off of eBay http://ebay.eu/1hgcZc7
They are a direct replacement for the dash bulbs - they are a touch on the big side but will go into 1275GT clocks, just. Replaced all of them apart from the oil press and alt charge check lights.
Here's the result - well pleased.
Go to the full post
Posted 31 October 2013 - 09:07 PM
I'm looking at installing some LED back lights on my 3 clock dash. Has any one got any instructions on how to do this and any led lights which they recommend on eBay etc which are bright and good quality?
Thanks for your help
Posted 31 October 2013 - 11:06 PM
i have done my twin clocks but i put the leds inside the clocks because the ones i got of ebay are not bright enough
Posted 01 November 2013 - 08:46 AM
Which LED's did you use?
Posted 01 November 2013 - 01:40 PM
If smiths centre clock, you need leds fitted to an E10 screw bulb,
If later 3 clock, you can get away with leds fitted to a T10 push bulb
to get hold of these, fleabay is your friend
Posted 01 November 2013 - 02:49 PM
Thanks, how many do you think i'd need? 5,10? they're only £2.49 for 5.
Posted 01 November 2013 - 04:40 PM
i usually get about 10 of a type, so i can keep spares
yes they're cheap enough :)
Posted 02 November 2013 - 06:55 PM
i used 4x 10mm leds in mine
Posted 06 November 2013 - 09:09 PM Best Answer
Just done mine.
Posted 06 November 2013 - 09:16 PM
Just done mine.
Definitely getting myself a set of those!
Posted 06 November 2013 - 09:22 PM
Oh yeah - forgot to mention - LEDs have to be installed with the correct polarity - i.e. negative to negative, positive to positive. Otherwise they don't illuminate. I worked it all out using a multimeter with the clocks on the bench and tested all with a 12v battery and test leads before installing in the car.
Posted 06 November 2013 - 09:43 PM
Posted 06 November 2013 - 09:59 PM
@sherly how many LEDs did you use? I bought 4 will that be enough?
I bought a set of 10 and used 6 (don't replace the alt charge light with an LED!)
to be honest if it's just the dials you want to illuminate with LEDs (and not indicators/main beam) you can get away with 3x
Just to check - What clocks have you got? Mine are in my GT and have t10 wedge type bulbs - not sure what the later clocks are like.
Posted 06 November 2013 - 10:02 PM
I'll try and get it done over the weekend and get some pictures up!
Thanks for all your help all
Posted 06 November 2013 - 10:15 PM
I have t10 bulbs too 3 clock, I've bought 4 of them and just want to illumine the main dials.
Which ones did you buy? (The link I posted here was for 10x bulbs)
Posted 11 November 2013 - 09:12 PM
I bought 4 of the link you posted instead of 10. Your right, they look awesome!
