Hello, Bit of advice needed really.
Getting a quite famous MPI Rally Car running again after a good 7 years since proper running. The engine now turns over and fires and runs ok.
However I am having some quite strange problems it still isn't 100%.
- The engine is running very Rich, Black soot around the exhaust after you rev up 3k+ also seems to be spitting black soot out as well.
- Engine idles ok around 900. And revs up fine if you take it very very slowly.
- Main problem is, when you push the throttle quickly the revs immediately drop to 0 and the car fights a stall. If you release the throttle immediately it usually recovers but if you hold the throttle down it stalls.
- The car isn't very drivable because obviously when you push the throttle down the revs drop immediately and it is very lumpy.
- No smoke white or black.
- I have changed the Coolant Temp Sensor and Checked Earths.
- Brand new Racing Spec battery.
- Runs an aftermarket MBE Engine management system.
What are the next things to try to get this running smoothly?
