Mpi Rally Car Running Poor
38 replies to this topic
#31 a13gpn
a13gpn
  • 18 posts
Posted 09 December 2013 - 04:49 PM
Stripped the engine down today ready for starting rebuild tomorrow.
Everything is filthy and sooted, gasket seems ok but will change anyway.
Some corrosion around some chambers on the head and block.
Wet with oil in piston 1+2 (obviously I poured some into number 2 for compression test) 3+4 are bone dry.
Lambda sensor is embarrassingly sooted. Will re-build everything, change a few possible suspect hoses and test again.
Debating pulling the whole engine out and restoring/painting everything now instead of later on as planned, the car is definitely worth the effort with its masses of history.
#32 a13gpn
a13gpn
  • 18 posts
Posted 21 December 2013 - 02:13 PM
Ok so another update..
Engine has new copper head gasket fitted and been torqued up correctly.
Everything has been cleaned up, flushed through and re-fitted. And new coolant and Lambda sensor fitted.
After starting the car again we seem to be possibly running slightly smoother but still have problems.
Loosing a lot of coolant, the expansion tank level has dropped from max to near the bottom already.
Black water coming out the exhaust along with a bit of hazy white smoke. (possible coolant, but could be slightly oily??)
Engine still stalls if you put your foot down inside the car, engine seems to revs better if you manually rev using the throttle body which is strange.
Unsure of where to go with this now.
#33 jaydee
jaydee
  • 8,565 posts
Posted 21 December 2013 - 02:23 PM
First the new gasket, it needs to be run through 3-4 heat cycles, then re-torqued when its completely cool down.
After that, it shouldnt eat coolant, at this point minimal bubbling between cylinder head and gasket is acceptable as it clears out after a bit of running in. Otherwise, try a leakdown test.
I wouldnt focus on exhaust smoke really.
#34 a13gpn
a13gpn
  • 18 posts
Posted 21 December 2013 - 02:29 PM
I have had it up to temperature twice now and re-torqued both times. At temp we also get a bit of wispy steam/smoke/gas(?) from where the inlet manifold meets the head.
The smoke isn't what bothers me about the exhaust, its the black water/oil covering the drive which signals alarm bells.
#35 jaydee
jaydee
  • 8,565 posts
Posted 21 December 2013 - 06:29 PM
Could be one of those unreliable copper gaskets around these days, a BK450 could be a better replacement
Try to trace leaks and see if you can get a leakdown test
#36 a13gpn
a13gpn
  • 18 posts
Posted 28 July 2014 - 07:32 PM
You will all be pleased to know the car had a full engine rebuild and is now running perfectly, 105BHP.
Soon to be featuring on the show circuit and select competition events.
#37 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 28 July 2014 - 11:03 PM
So the problems where purely mechanical after all?
#38 a13gpn
a13gpn
  • 18 posts
Posted 28 July 2014 - 11:07 PM
The head had been overtightened sometime in its life and it had slightly warped the block, so the engine did have compression problems causing it to run poorly. All sorted now, fully rebuilt by top race engine specialists Paul Inch.
#39 bloke
bloke
  • 139 posts
Posted 29 July 2014 - 08:48 AM
Paul's a good bloke, plus he has a workshop to die for. :) You'll always find Mini's outside, his daughter races them in the mighty mini series.
