Engine To Gearbox Dowel
6 replies to this topic
#1 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 03 November 2013 - 03:42 PM
Are there two locating dowels that sit between the engine and gearbox At the backmof the block, one either end. Ive taken some photos to describe the holes i am on about. If so where do I get them from. I am about to order the minispares gearbox to block fitting kit but I can't find any.
#2 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 03 November 2013 - 04:58 PM
Hello Jack,
Somerford Minis show the dowels you need as part No 22H983.
Also from memory I know one of the gearbox-to-block dowels is "hollow" to allow a bolt to pass down through it. The head of the bolt sits in the recess of a thick washer.
Hope this helps. Hopefully someone will be along shortly with a better memory than mine!!!
Steve.
#3 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 03 November 2013 - 05:13 PM
Fantastic! Well its more information than I had, so thank you!
#4 Stevie W
Stevie W
  • 1,204 posts
Posted 03 November 2013 - 05:15 PM
No probs....glad to help :-)
#5 Stevie W
Stevie W
  • 1,204 posts
Posted 03 November 2013 - 05:34 PM
Hello again Jack,
Just done a bit more digging, and the hollow dowel you need is part No 12H1824.
This dowel goes nearest the flywheel end.
Guessworks on here will probably be able to help you with both dowels!!
Steve.
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 03 November 2013 - 05:46 PM
http://www.guess-wor...arbox to engine
#7 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 03 November 2013 - 05:47 PM
Lovelyy! Thanks all
