This Mini is finished to the very highest standard. It was originally prepared by TDK Racing and raced in the Dunlop Mini Miglia championship by Dave Kimberley. Since then the car has undergone a full restoration and has been converted for use on the road. Since the restoration the car has only covered 250 miles and has NEVER been used on winter roads or in the rain!
The car has MOT till May 2014 and is taxed until April 2014 (TAX FREE 1971 car).
Last winter the car was taken back to a bare shell and has been fully rebuilt and restored. All rust was cut out or treated if it was superficial. Mounting bolts, nuts, fixtures etc. have all been reconditioned or replaced. Bolt on components, subframes, interior etc. have all been reconditioned and painted etc.
The current spec of this car is HUGE:
EXTRAS
Polycarbonate front screen (Still with Dunlop Mini Miglia Challenge sun strip)
Five rare 10" Spectrum Split Rims (4 with slicks)
Four Miglia arches
SHELL and EXTERIOR
Mini Miglia spec fully seam-welded shell, (Now showing a few minor superficial spots of surface rust around the roof gutter)
Carbon Fibre removable front end with carbon fibre bonnet and carbon fibre boot lid (Some minor scratches and crazing of the gelcoat on the front end)
Fibreglass wide arches
Extended internal rear arches to accomodate wider wheels
Front end brace bars
Light weight race doors
Bronze polycarbonate windows complete with slide on driver’s window
NEW Heated windscreen
Clear rear light lenses
Clear front indicator lenses
Single wiper conversion
Battery kill in scuttle panel
Lifeline electronic fire extinguisher system (Plumbed in to nozzles, needs wiring)
INTERIOR
Carbon Fibre Dashboard & Centre console
Carbon Fibre doorcards, parcel shelf and rear 1/4 cards.
Lightweight fibreglass boot floor
Full Safety Devices roll cage with safety devices protective padding
Two bucket seats with harnesses (Drivers side Cobra 400 stealth on rails, passenger Sparco Sprint 5)
Custom quick shifter with custom gear knob
Internal floor mounted gear change
Racetech water temperature and oil pressure gauges.
Elliot rev counter
Smiths 130mph speedo
ATL fuel gauge & sender unit
Battery behind front seats
Lowered steering column with brace bars
Large low oil pressure warning light
ENGINE
1275cc A+ engine
Freshly rebuilt engine with new main and big end bearings
Twin 45 weber on long manifold
Billet ultralight flywheel
New clutch and diaphragm
New alternator
3-1 Race LCB
Playmini 2.5" stainless steel straight through exhaust system with 1 silencer box
Red top facet fuel pump
Fuel pressure regulator
Aluminium 4 gallon race fuel cell in the boot
Braided fuel lines run inside the car
Solid engine mounts
Adjustable top engine steady
BRAKES
4 Piston alloy callipers with 7.5" vented discs
Mini Superfins fitted to the rear with New brake shoes
AP Racing Master Cylinders with remote reservoirs
AP Racing 551 brake fluid
Stainless steel braided brake lines throughout inside car
Tilton brake bias adjuster
Relocated handbrake lever
KAD alloy handbrake quadrants
SUSPENSION
Gaz Super 7 dampers all round with lowered front mounting brackets
Hi-Lo's all round
New bushes, dust covers, radius arm rebuild kits, steering arms, track rod ends
Rear negative camber brackets
Brand new Quickrack steering rack
10" Revolution alloys with Yokohama tyres and spare Revolution alloy wheel with Falken tyre
ELECTRICS
Custom heavy duty wiring harness with modern relays & fuse box
Battery master kill switch in centre of dash
Key ignition in dash with starter switch
This car is truly stunning, is amazing to drive and is reliable. Even in fully road legal spec this mini weighs just 606kg! The mini will come with the 10" Revolution alloys on the car as the slicks are not road legal. Both sets of wheels are on the car in the pictures for illustrative purposes only. The car is located in Bexley, South East London. £6995 ovno.
Edited by dancecommander, 03 November 2013 - 04:00 PM.
