Gear Selector Problems
11 replies to this topic
#1 welderman
welderman
  • 330 posts
Posted 04 November 2013 - 04:04 PM
Hi there, having problems selecting gears after an engine change.
Engine 1275
Rod change
I can select 3rd and 4th gear only
cant get 1st or second or even reverse.
Next step is to try selecting gears straight from the box using the selector sticking out the engine.
Any other ideas or things that might be of help.
Thanks Joe
Edited by welderman, 04 November 2013 - 04:12 PM.
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 04 November 2013 - 04:52 PM
Can you move the gearstick across the gate (left and right)
#3 welderman
welderman
  • 330 posts
Posted 04 November 2013 - 04:54 PM
Yes. It feels as if I can select all the gears. That's with it running or not running. But only engages in 3rd and 4th.
#4 welderman
welderman
  • 330 posts
Posted 04 November 2013 - 04:58 PM
Just to Point out. I took the car on the road. Thought it was a bit slow getting away in first. Changed to second then third. That's when I realized it was third I set off in when the car screamed help I'm third again !
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 04 November 2013 - 05:27 PM
Take the gearstick out and see if the ball is still on the end of it...
#6 welderman
welderman
  • 330 posts
Posted 04 November 2013 - 06:26 PM
Ball was on when I put it back. But will check :)
#7 welderman
welderman
  • 330 posts
Posted 05 November 2013 - 10:51 AM
Right the stick looks ok complete with ball. Will take a pic in a min.
Bit of a thought though, if you push the lever forward and engage say 3rd gear, you can move the stick left to right quite easily. Cant seen to find a slot for 1st even if you just slightly pull it out and try to find another slot. :(
#8 Roadrunner-Be-Beep
Roadrunner-Be-Beep
    Starting My Mini Up
  • 3 posts
Posted 05 November 2013 - 12:30 PM
Easy fix - it is likely that you have put the gearbox selector rod back in 180 degrees out.  Take out the gearstick knock out the roll pin on the rod coupling at the back of the gearbox and turn the rod 180 degrees, put the roll pin back in, put gearstick back in and select all the gears as normal.
#9 welderman
welderman
  • 330 posts
Posted 05 November 2013 - 12:42 PM
Realy is it that simple, will give it a go cheers
#10 welderman
welderman
  • 330 posts
Posted 05 November 2013 - 01:58 PM
Looks like that's sorted it, need to get it on the road to give a check out, but thanks for the replies chaps, love car forums.
#11 Roadrunner-Be-Beep
Roadrunner-Be-Beep
    Starting My Mini Up
  • 3 posts
Posted 05 November 2013 - 05:40 PM
Glad to be able to help.  I can imagine your frustration - the same thing happened to me before.
#12 welderman
welderman
  • 330 posts
Posted 05 November 2013 - 09:19 PM
Funny how it takes a simple thing to get your blood boiling :0
