I'm trying to make a list of things that need to be done as far as body work. I'm looking to eventually fit 12x6 inch deep dish Superlights and I was wondering if someone could describe the exact process that needs to be done as far as modifying the arches, or point me in the direction of a webpage or manual with specific fitting instructions.
Cheers,
- GK
Fitting 12 X 6 Inch Rims.
Posted 05 November 2013 - 03:00 AM
Posted 05 November 2013 - 10:20 AM
Hopefully this is a link to a Keith Claver article, right down the bottom of the page he describes how to modify the front wheel arch
http://www.minimania...t_Consideration
Posted 05 November 2013 - 12:07 PM
Some 12x6 will fit with no arch mods. Its all about the offset.
Posted 06 November 2013 - 04:18 AM
Thanks! This is exactly what I was looking for.
Really? I'm thinking of putting spacers on because I have a feeling the Superlights wont be flush with Sportspack arches. In that case, do you think I could still get away with it? I read somewhere that with 12x6 inch rims you definetly need to modify the arches to fit.
Posted 06 November 2013 - 09:10 PM
Technically he is right, some 12x6 don't require any mods, however it is incredibly likely considering they are deep-dish superlights. As always make sure you are getting the right offset of wheel to reduce the need for spacers.
Posted 07 November 2013 - 01:03 AM
Thanks! What offset would you recommend with Sportspack arches?
Posted 07 November 2013 - 07:00 AM
Sportspack arches are 6" wide, so for instance if you fitted these 'http://www.midlandwh...ght-Silver.html' They have an offset of ET 0, so in theory you should see half of the wheel width covers over the caliper/disk and the other half will protrude from the arch, which is 3". You would need a spacer, and a fairly fat one too. This is because people mostly use a 13x7 wheel with the sportspack, because dished wheels are available up to an ET of -7and they are also an inch wider, so the dish is larger.
Edit: This may help you understand
Edited by Yams, 07 November 2013 - 07:04 AM.
Posted 08 November 2013 - 05:24 AM
Posted 09 November 2013 - 06:43 PM
If you were to fit the wheels i linked you'd have to use a wheel spacer for the wheel to sit flush with the arch.
Posted 10 November 2013 - 02:11 AM
Posted 10 November 2013 - 02:14 AM
http://www.midlandwh...ight-Black.html
Posted 10 November 2013 - 09:06 AM
The offset is ET-7 so it simply means that the hub face of the wheel is set in by 7mm from the centre. This could mean a deeper dish, but it defiantly means that the outside edge of the wheel will poke out 7mm more than a wheel with ET 0 offset.
Posted 10 November 2013 - 06:24 PM
Thanks for all your help Yams!
Posted 11 November 2013 - 09:08 PM
Have you though about fitting different arches?
I have 12x6 superlights on my car with group 4 arches and the wheels fill the arches perfectly. The arches do still have to be modified, but spacers aren't needed.
Posted 12 November 2013 - 05:27 AM
Since I'll be buying Moulton Smootha Ride suspension, I might just bite the bullet and slap some thirteens on. I'm just worried about handling and losing power.
