you need the same starter, but you technically don't need that wing mounted solenoid now.
The starter needs to match the flywheel not the wiring of the car.
So if you've kept everything the same and thats the starter that was on, you use same starter and adjust wiring to suit
Easiest would be to run your battery cable direct to the starter motor assuming its long enough.
extend the wire that energises the wing mounted solenoid to reach the starter motor large spade connection
then run some high ampage cable from the starter motor battery connection to the wing mounted solenoid and attach it to the terminal with all the brown wires attached.
Edited by lrostoke, 07 November 2013 - 11:45 AM.
