New Followers With An Old Cam
8 replies to this topic
#1 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 08 November 2013 - 04:17 PM
So my engine is all stripped now, and I didn't think to number the cam followers so I knew where they went.
This means I now have four (the other four fell somewhere and I can't find them) random followers that I guess I can't use now.
My only other option is to buy some new followers but I've heard this isn't good if you're reusing an old (35000 mile) cam. It is an MG Metro cam so it isn't an option to buy a new one as I don't have endless funds.
Any thoughts on this? What would you do?
I did do a search to no avail.
Edited by HarrysMini, 08 November 2013 - 04:17 PM.
#2 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 08 November 2013 - 04:22 PM
stick new followers in there...
#3 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 08 November 2013 - 04:52 PM
+1 for new followers
#4 greenwheels
greenwheels
  • 689 posts
  • Local Club: Mini Fixers
Posted 08 November 2013 - 04:58 PM
The cam lobe surfaces will be work hardened, so the new cam followers will be most likely the side to wear, but I would not worry about it. Can't see what else you could do.
#5 Cooperman
  • 23,326 posts
Posted 08 November 2013 - 05:09 PM
Just fit new followers and you'll have no problems
#6 HarrysMini
HarrysMini
  • 3,352 posts
Posted 08 November 2013 - 05:11 PM
Okay, thanks guys. I'll order some new followers.
#7 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 08 November 2013 - 06:42 PM
Last year i fitted new followers in my 998 while i had the engine out, the engine had about 60000miles on it and ive probably done about another 8000 with no problems
#8 jaydee
jaydee
  • 8,565 posts
Posted 10 November 2013 - 02:23 PM
Dont forget to use some engine lube and remember that the new followers need to bed-in to the camshaft. Run it for about 20 minutes between 2000 and 3000 rpm and dont let it tickover for its first 30 minutes of life.
#9 HarrysMini
HarrysMini
  • 3,352 posts
Posted 10 November 2013 - 04:52 PM
Okay, thank you for confirming that. I thought that's what I should do.
