Crank Position Sensor Question
Posted 10 November 2013 - 12:54 PM
Posted 10 November 2013 - 01:58 PM
Hi, Omex suggest the coil feeds are switched (IGN) 12v via a suitable relay, have you checked for 12v on the centre pin (2) of the Coil connector?
The CPS needs to be as close as possible to the trigger wheel and use shielded cable with the shield terminated to ground at one end only close to the ECU, what type of CPS are you using?
http://omextechnolog...lation 2v00.pdf
Posted 10 November 2013 - 02:10 PM
Posted 10 November 2013 - 03:19 PM
sounds like you have a trigger wheel thats been added to an exisiting crank pulley, hate to say it but they are known to be unreliable some have even moved out of position whilst driving not the best solution but I'd look for new crank pulley like the MED unit also incorporates a damper.
Posted 10 November 2013 - 03:40 PM
