Scary Steering ..
Posted 10 November 2013 - 02:38 PM
Any help or advice on this is appreciated as always !
Josh
Posted 10 November 2013 - 02:51 PM
steering rack - steering coloumn spiles.
this is a serious fault please check it.
The bottom of your steering col is a female spline, tightened with a 6mm roughly bolt through the clamp.
the steering rack is a male stub with splines.
one or both of these components are worn/damaged.
Posted 10 November 2013 - 03:09 PM
Have you got a drop bracket installed?
As Jordie says this is a serious fault and needs sorting before you can safely drive your mini. Do not drive it until you have resolved your problem.
Get the column off and inspect the splines on both it and the rack for any wear.
Posted 10 November 2013 - 03:12 PM
Thanks for the replies
Josh
Posted 10 November 2013 - 03:25 PM
check the rack retaining brackets are tight (4 1/2" nuts under the carpet) this can cause this interesting problem too
Posted 10 November 2013 - 03:35 PM
get someone in the car to turn the wheel and just go through all steering components looking for play just hold each peace as he gives the wheel a wobble and you will be able to feel where the play is, my bet is on the rack or the u bolts that hold it on , is there much play in the rack when its not moving and you turn the wheel ?
Posted 10 November 2013 - 05:16 PM
+1 for Minidaves suggestion, this happened to me recently. Gives very 'interesting' characteristics - when you go into corners suddenly get lots of understeer and overall vicious handling. Not pleasant.
Tightening up the rack securing clamp bolts transformed it completely.
Yes waddle there is a bit of play even when not steering
Posted 10 November 2013 - 07:50 PM
Posted 10 November 2013 - 11:24 PM
Thanks again for the replys
Josh
Posted 10 November 2013 - 11:26 PM
Posted 11 November 2013 - 07:08 PM
Can't find these 4 1/2" nuts :-Scheck the rack retaining brackets are tight (4 1/2" nuts under the carpet) this can cause this interesting problem too
image.jpg 43.61K
7 downloadsThis is the only clamp under my carpets
Could it be these nuts under the car holding the steering rack on ?
image.jpg 54.06K
8 downloads
Posted 11 November 2013 - 07:24 PM
Posted 11 November 2013 - 07:28 PM
Posted 11 November 2013 - 07:31 PM
