Misfire? Strange Problem.
Posted 10 November 2013 - 05:23 PM
The car is running pretty rough, we have checked all vacuum pipes but it still runs bad.
We even put the old points back on and it'd still horrible to drive.
Im really losing my patience with this car, any help would be great.
Posted 10 November 2013 - 05:28 PM
Posted 10 November 2013 - 05:30 PM
re set the timing, piston no1(radiator side of engine) at tdc, then put your electronic dizzy in with the rotor arm at roughly 1 oclock position, then try start the car(rotate the distributor body slowly until the car starts), then increase the idle to 1000 rpm, untill you hear a slight pinking, then retard the dizzy slightly. you might need to fine tune the timing by rotating the dizzy if the car is hesitant under load.
Posted 10 November 2013 - 05:44 PM
Posted 10 November 2013 - 07:03 PM
is the timing mark an arrow? its a 1982 city!
anyone shed some light on this? I'm desperate!
Posted 10 November 2013 - 07:10 PM
compression readings were
174 130 130 116
Posted 10 November 2013 - 07:14 PM
that's not good, regardless of timing those figures and the last 3 are really low.
could be ring problems, or if your lucky valves need adjusting
the arrow is the timing marker, and on the pulley should be a notch
In fact its a big arrow, with about 4 or 5 smaller peaks
did you have throttle open as you took each reading
Edited by lrostoke, 10 November 2013 - 07:15 PM.
Posted 10 November 2013 - 07:20 PM
yeah I noticed the big arrow. So where do I go from here?
what should the readings be roughly?
Posted 10 November 2013 - 07:39 PM
174 130 130 116
Compression readings should all be within 5-10 psi.
Did you have all of the plugs out and the engine warm when doing the tests? Also was the battery still spinning the motor over at the same speed on the last reading as the first one - this 116 is really low.
Posted 10 November 2013 - 07:44 PM
you 175 is about right, then they just get worse..Like carbon says was the battery still strong for each test
Posted 10 November 2013 - 07:46 PM
Posted 10 November 2013 - 07:58 PM
Posted 11 November 2013 - 09:26 AM
Posted 11 November 2013 - 10:12 AM
what I dont understand is that the misfire only happened when I installed the electric ignition and when we put the points back on it was still misfiring.
