Before Dropping My Engine In.....
Posted 11 November 2013 - 07:50 PM
Posted 11 November 2013 - 07:58 PM
depends what you've done
but fuel pipes and front to rear brake pipes are a good thing make sure are in place.
make sure front brake pipes and flexi pipes are fitted.
front suspension especially top arms, easier get at the pivot shaft with engine out.
engine just fit anything that's a pig to fit once its in, so if mechanical fuel pump make sure fitted.
bit of an open ended question without knowing whats done and not
Edited by lrostoke, 11 November 2013 - 07:58 PM.
Posted 11 November 2013 - 08:06 PM
Fit the speedo cable to the engine before dropping the engine in
How old is the clutch?
gear change shaft oil seal?
Posted 11 November 2013 - 08:11 PM
Brand new clutch as I've rebuilt the engine
Posted 11 November 2013 - 08:13 PM
Yeh done most of that! Just wanted make sure nothing major had to done what I haven't donealready
