Help With Primary Gear Please
34 replies to this topic
#16 minilee94
minilee94
  • 3,523 posts
Posted 17 November 2013 - 09:39 PM
Right okay I'm very quickly getting the hump with this crap buying bits then having to have to fitted then played with by a machine shop pissing me right of now
#17 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 17 November 2013 - 09:47 PM
you need this  http://www.minispare...A3240.aspx|Back to
a press to fit it, a micrometer to measure your crank, a lathe to bore it out to the correct clearance, make sure its clocked in before boring, concentricity being the key here, a machine shop will be able to do all of this no problems.
to be fair you would be taking a chance buying a second hand unit and it being ready to fit with the correct clearance for your crank, that said the one sold to you is clearly scrap
#18 minilee94
minilee94
  • 3,523 posts
Posted 17 November 2013 - 10:00 PM
So when you buy a set of new straight cut drops how do people just fit them and that it because its bullish!t paying £300 for gears then paying to get them bored out
Or will it be different story as my crank is brand new
#19 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 17 November 2013 - 10:07 PM
well I'm not sure about new straight cut drops and if they need machining but a used second hand one is going to have some kind of wear....
as an example: I bought a new X pin diff and I ended up replacing the bush as it had to much clearance, slack as f***, so even when buying new I wouldnt assume its a case of fit and forget, it should be but it isn't always
#20 minilee94
minilee94
  • 3,523 posts
Posted 17 November 2013 - 10:17 PM
Right okay well I might just buy a new set of drops and go from there £250 for a new set
#21 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 17 November 2013 - 10:28 PM
go for it
I would still be doing some measuring before they went together though, new or not
#22 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 17 November 2013 - 11:13 PM
For that sort of thing id not buy second hand anyway.. You have no idea of condition and it could be cracked! I got a set and crack detected it at work- was scrap metal.. It would have thrown teeth around in about 10mins of running!
New- is always cheaper in the long run!
#23 minilee94
minilee94
  • 3,523 posts
Posted 18 November 2013 - 05:40 AM
Yeah true well il measure my crank then look in to some new drop gears
#24 Cooperman
  • 23,513 posts
Posted 18 November 2013 - 04:44 PM
Engineering is about measuring, calculating and machining.
If you don't do it then you will end up with a very poor end result.
There are so many variants of parts for Minis, like different pistons and piston dish volumes, different transfer gear cases, different con-rods, the list goes on and on. With any classic car you have an old designed product range so everything must be measured and 'engineered' to be sure it will work properly.
The alternative is a modern car.
#25 minilee94
minilee94
  • 3,523 posts
Posted 18 November 2013 - 09:32 PM
Well my crank is brand new and if I buy new drop gears surely try will fit nicely
Obv I will still measure it but that's bill crap buying a crank or drop gears and having more work done just for it to fit
#26 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 18 November 2013 - 09:50 PM
Why do you think people pay Other people to build and engineer their cars for them?
Because everything has to be done right and engineered properly! I don't think I have fitted a part to any of our race cars that just bolts on, everything always gets modified, or made to fit
#27 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 18 November 2013 - 10:00 PM
it might do
but think about this; you fit a new bush and have it machined then it will definitly fit and cost a whole lot less
#28 minilee94
minilee94
  • 3,523 posts
Posted 18 November 2013 - 10:06 PM
Having it machined and a new bush fitted I dout will be much less than a set of new straight cut drops
#29 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 18 November 2013 - 10:15 PM
it will be cheaper and will fit correctly
#30 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 19 November 2013 - 12:52 PM
You'd have to get a new straight cut primary gear checked and then possibly machined too.  You should really get a second hand one checked even if it looked perfect.  The reason there are so many badly built engines out there is that people are just buying second hand performance parts and then slapping them together and turning the key.
Then you also get the "I can build you a race engine for £500" type.  It's this sort of detail that is often/always overlooked and then causes problems later on.
