When driving up a hill my Mini overheated and cut out.
So this weekend I replaced the thermostat and water pump and flushed and reverse flushed the system until it ran clear.
The only issues I found were a lot of rusty gunk blocking the top of the thermostat and some rust coloured water in the system.
After completing the work I ran the car up to temperature (half way on the gauge) and found it is pushing water out of the overflow and leaking oil from somewhere.
When I turn the engine off I can hear either water or oil boiling in the engine.
There is no evidence of water and oil mixing and the car runs fine, with only a loss of power going up big hills due to timing issues.
I have ordered a compression tester to get more diagnostics.
Does anyone have any ideas what might be causing the issue?.
Cheers.
Iggy.
